Old 11-30-2008   #31
Pete
Pete's Avatar
Default Re: Track Times: My Best Ever
Originally Posted by Locobob View Post
My math shows 129mph at 7500rpms with 3.45's and 25.7in tires - I'd say thats just about perfect for the quarter mile assuming your powerband looks a lot like mine. If you're gonna try gears I'd go with at least 4.10's otherwise you'll end the quarter part way through 4th and the extra gearing may not compensate for the time it takes for the extra shift. Your results are making me seriously think about doing a cam swap - stop it already
I was running 26.2" tall tire.
Bob,yes your right 4.10 is perfect for 1/4.
My peak comes in just shy of 6800 474rwhp, 5200 400rwtq
The cams are worth 20 RWHP.
Cam specs
.236 .425 In
.220 .425 Ex
Some cam sound at idle,drives like a stocker,throttle response furgataboutit.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 12-01-2008   #32
jonszr1
jonszr1's Avatar
pete, talked with my suspension guy he seems to think that you can use 4.10 gear if you go to a 27in tall tire if you stay with the tire you have now your wheel speed ie tq multiplication will blow the tires off ruining your 60fts . i shared your dyno results with him . he also thinks that you might find that shifting at 7200 would help. the reason he thought3.92 would work is the fact that you are using the 315-335x35x 17 tire. he was worring about your wheel speed off the line . just food for thought
Old 12-27-2008   #33
Jagdpanzer
Jagdpanzer's Avatar
Those skinny a-molds would get a lot of attention/compliments.
Can you send me some pictures of the wheels with the Hoosiers on them.
Pete
Hey Pete,
It was absolutely gorgeous outside today here in northern Virginia so I rolled the Z out and took a few pics of it with the narrowed A-moulds and Hoosiers mounted up:
Old 12-27-2008   #34
flyin ryan
flyin ryan's Avatar
you must notice the steering being a little lighter when going slow, huh. run 11.99 E.T. or quicker & you have to have steel valve stems, BTW. i'll tell ya' why if anyone is interested
Old 12-28-2008   #35
Aurora40
Aurora40's Avatar
They look good until you turn the wheel out. Those skinny tires just look wrong on a 'vette! Pretty neat for a skinny though.
Old 12-28-2008   #36
Jagdpanzer
Jagdpanzer's Avatar
Yes they turn a lot easier at slow speed the regular size Michelin Pilots and GY D3 fronts I have and they handle surprisingly well at higher straight line speeds to. However, I don't expect I'll be doing any frisky cornering with them tough.
Nothing would please me more to have to change to steel valve stems
Bob,
I feel the same way but fortunately you're not suppose the do much turning in drag racing.
Old 12-28-2008   #37
Pete
Pete's Avatar
I'm suprised the tread depth on those Hoosiers, they look like you can drive around town with those.
Probably makes the rears look wider.
I had the spare donuts on them and ran at the track twice 125MPH runs trust me i was worried but they suprised me,stoped with no issues.
I'm sure the Hoosiers are better then the spare donuts that i used.
Side profile looks stock.
They look awesome.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 12-29-2008   #38
8upZR1
8upZR1's Avatar
FR,
So why do you need steel stems faster then 11.99?
