Old 01-18-2009   #1
Jarek5_7
Default high idle
I have high idle , around 1100 or little more rpm.
on datamaster desired idle is 650. recently I changed plenum gaskets, injectors, coils, spark plugs and wires because there was a problem with ingnition, miss etc. now the only problem left is high idle.
(oh maybe not the only but most annoying)
I`ve read that tps v should be from 0.54 to 6v
mine at idle are around 0.24v
other thing is how to check iac?
datamaster shows that iac is 0 on idle , whem I rev a little it goes to 30 and them falls to 0, with it rpm falls but now as low as I wanted it to be.
is the a way to check iac? or to calibrate it?
Jarek5_7 is offline   Reply With Quote
Old 01-18-2009   #2
Default Re: high idle
The fact that the IAC count is 0 at idle suggests that there is bypass air
present. Does idle drop to 700 or so if you stab the pedal?
Did you move TPS? With scantool in place, move throttle from closed to open and back
Does it feel smooth? Do volts seem to hang or move in a abrupt or choppy manner?
Old 01-18-2009   #3
Jarek5_7
the idle dont drop even below 1000.
I dodnt move tps. volts from tps move smoothly.
what do You mean by bypass air present?
is 0 the middle position for IAC? is the middle position for iac the required position to maitain idle (650) rpm?
by bypass air present you meant the air bypass by half opened aic?
Old 01-18-2009   #4
Demps
Demps's Avatar
First thing I would check (since you just performed work) is the hose under the throttle body. You can see the "L" shaped fitting pointed aft from the driver's side under the TPS-->get a small flashlight and mirror. If not attached, you will have a high idle. Sometimes you can attach it without removing the plenum again. The rubber hose has a compression-type clamp on it.
Also, the TPS is adjustable and should read correctly.
Ted
Old 01-18-2009   #5
Jarek5_7
It had high idle before the work I did. I think I know about which hose you r talking about, I think its in place, but I`ll check it again.
so what v should tps at idle have? 0.54?
Old 01-18-2009   #6
Jarek,
0 steps for IAC means it's completely closed. Outside air is getting in some other way. Throttle plates may be opened too far or there's an air leak.
Loosen TPS and set it to .5v with scantool connected. You'll do that with
ignition on, motor off.
Old 01-18-2009   #7
tpepmeie
Ted
I'm with Ted... the canister purge hose under the front driver side of the plenum is likely disconnected, which will cause the massive air leak = high idle. That was the first troubleshooting I did on my '91 back in 1999.
Old 01-18-2009   #8
He mentioned that it had a high idle even before he did the plenum removal.
So whatever is causing high idle hasn't been affected.
Surprising he 's not getting code for LO TPS V.
Old 01-18-2009   #9
Pete
Pete's Avatar
Basicly you have a vacuum leak.
I spray a mist of water around the gasket and vacuum ports/hoses if the idle starts to fluctuate you found your vacuum leak,good luck.
You need to adjust your TPS to .55
You need to have 10-20 IAC counts at idle.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-18-2009   #10
Jeffvette
Correctly set your TPS, and I think you will find the high idle will go away.
