Old 05-02-2009   #11
ZR1Vette
ZR1Vette's Avatar
Default Re: Half Shaft Mystery
1990 #622 was the switch over from steel to aluminum. Maybe prior owner switched from steel to aluminum (some have done that for "weight savings" and looks (no rust)
Old 05-02-2009   #12
Scrrem
Scrrem's Avatar
I have 1990 #608 and mine are steel.
Rich
Originally Posted by Kevin View Post
Mark,
For some reason the number 165 is stuck in my head as the change over for half shafts. enjoy the car
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 05-02-2009   #13
WVZR-1
my question is : is there a chance these alum. half shafts were intalled at the factory on such an early car, or have they been replaced? It seems very strange that they would be replaced with such low mileage. I found the following part numbers on stickers on the shafts: right side 14041925 - AR8??3, left side 14041925 - AR5033.
The part # is/was a "production" shaft used for very early C4's. It has "service/replacement" applications in early parts catalogs for '84 MY only. I would have guessed the AR5033 to be a date code and my thought would have been '85 33'd day of year. The AR8??3 though would seem to disprove that. It's I believe though very safe to assume they're "replacements" and not '90 MY production parts.
Here's a thought for you! The car left on a "test drive" with the "steel" and returned with the "aluminum"!! More difficult "swaps" have been accomplished!!
Old 05-02-2009   #14
FNG90-195 Congrats and welcome to the Zoo.
Old 05-02-2009   #15
FNG90-195
I appreciate everyone's input. The test drive/swap theory has got me thinking. So now my question is, are the aluminun half shafts I have now, that are from an early C-4, strong enough to stand a beating from a ZR-1? And if someone had an earlier C-4 with these aluminum shafts in it, would there be any reason for them to prefer the steel half shafts?
Also, anyone out there have a set of used steel half shafts for sale? If there are some around, what kind of $ do they usually sell for?
Won't sleep well tonight thinking about this one. All opinions welcome and appreciated.
FNG90-195 is offline   Reply With Quote
Old 05-03-2009   #16
tccrab
tccrab's Avatar
Jim VanDorn said in post #7 that he might have a set upstairs at his Pirate Lair.
Drop him an email, see if he's interested in parting with them.
TomC
"Crabs"
Old 05-04-2009   #17
FNG90-195
Thanks Tom. I'll give Jim a shout.
