Old 05-08-2009   #1
stedi
stedi's Avatar
Default Starter question
Original starter is discontinued by GM up here in Canada. My question is can a rebuilt/jobber do the job. I've heard some people say that since the started is placed mid-engine and is exposed to high heat, rebuilt starters could be problematic. Any comments or suggestions?
Thanks,
Steve
stedi is offline   Reply With Quote
Old 05-08-2009   #2
Default Re: Starter question
Well Ive been running my $79 rebuilt starter off Ebay for 2.5 years now in Arizona daily. So I have to say it depends on the feedback rating of the rebuilder.
Old 05-08-2009   #3
is it the same seller on ebay now?
Old 05-08-2009   #4
Grand yes
Old 05-08-2009   #5
WVZR-1
Thanks,
Steve
Your starter can be "repaired" on "the bench" by any competent "starter/alternator" facility. Rebuilt "implies" many things that sometimes don't happen! If yours is a "hot start" solution or an attempt at a repair to eliminate a "hot start" the "solenoid contacts" in the Nippondenso starter is is it's generally considered "weak point"! Not just the LT5 application but most Nippondenso applications. A more substantial "solenoid contact" package is a $10-part (in quanity substantially less). That package and the replacement of the "plunger" maybe another $10 should accomplish "the fix"!!
I'd ask a compentent local shop to see if they agree! The "contact, brushes and a plunger" maybe less than $50 on "the bench" and no shipping.
I've spoken to a couple local "rebuilders" and they feel the same regarding the Nippendenso product. Those parts and 12V at the starter and it "will" crank!! 12V nothing less!!
*I didn't see the other "no start" thread until after I'd commented here! The contacts, plunger, brushes and 12V is "the fix"!! This isn't a "fix" for all "no starts" but a good fix for a "hot no start"!!
Old 05-08-2009   #6
Thanks for that info.. I will order a solenoid kit for my car then
Old 05-08-2009   #7
WVZR-1
I'd visit a "local builder" for the parts. They'll use and have the "heavy duty" parts. Here's a link to a "typical Nippendenso" build!!
http://www.nationsautoelectric.com/Nippondenso.html
Here's a "small parts list"! for the 1998585 LT5 starter! A "local builder" can ID from this information. Click on the part# for image!
http://www.wai-wetherill.com/product...O&item=1998585
You can click on "vehicle look-up" on that page to access complete information for "most" electrical including our alternators. I didn't include a direct link because there are "two applications" I believe '90 and '91+! Take a look!!
Old 05-09-2009   #8
jonszr1
jonszr1's Avatar
napa also sells a great rebuild had one in my blk zr1 for 4 yrs
Old 05-09-2009   #9
flyin ryan
flyin ryan's Avatar
You should be able to get it rebuilt locally no problem.
Old 05-09-2009   #10
stedi
stedi's Avatar
Does that mean that if starter doesn't get 12V or more it will not even turn? My problem is that sometimes it turns, sometimes it doesn't. Doesn't matter if hot or cold, problem is sporadic. What is Nippendenso - the Solenoid?
Steve
