![]() Join Date: Oct 2008
I know the consensus has been to use a whitening toothpaste, but I was wondering if anyone has come up with something that might work better. Or maybe I'm not using the toothpaste correctly. I put it on a dampened soft cloth, rub lightly and then use a dampened clth to wipe it off with. I also tried a clay bar (no bueno).
Jim |
pretty much anything you are going to try is going to discolor the motor. your best bet is to get it painted or powder coated the color you want. edit: do no wash it
It's not the car, it's the people - Doug Johnson 90 r/r "KEYS ON" nick named "T.L.B" Last edited by Kevin; 06-06-2009 at 03:56 PM. |
#3 | |
![]() Join Date: Aug 2006
From what Ive experienced and from what Ive read if it does come off fairly easy its best to leave it alone.With this finish the more you rub the worse it gets.
#5 | |
![]() Join Date: Sep 2005
I use a little water and a clean microfiber towel...comes up nice!
![]() Join Date: Nov 2007
I noticed the color of the paint below the surface of my plenum was pretty much identical to the surface. So, I would have to conclude that the factory paint darkens with age/heat/grime (or all of the above!
![]() ![]() ![]() Painting or powder coating seems like the way to go. P. |
Before I painted my plenum, IH's and valve covers I had the usual discoloration of the factory paint. I was able to get the blotchiness and stains out by using a very light application acetone on a clean rag. You have to keep in mind that acetone will attack the paint. So it is very important to use a minimum of acetone on the rag and wipe across the paint lightly. You will find that it takes off the surface oxidation and grime. You will be able to even out the painted surface very nicely. Again, use too much and/or rub too hard and you'll go through the paint.
Good luck... H ![]() |
