Re: Paint care for your Z.
Here is what I have been using for the past year and love it. I could not remember what it was called initially, but I imagine this is like Zaino (maybe?)
You'll notice it mentions use on BOATS/fiberglass......Don't we have a BOAT engine  .
I love it because I use it for everything including the glass and my CCW wheels.
Like someone already said, personal preference and you end up sticking with something that works for you. I don't know if my paint can look any better than it does but I might try Zaino some day if I see one in person and like it.
Frequently Asked Questions - Why haven?t I heard of KLASSE before?
Although KLASSE has been the bench mark of surface care products for over 11 years, our major market has been the West Coast. Until recently, it was never advertised. Instead, we relied strictly on word-of- mouth, which is still our most successful technique. It took almost 12 years for the "grapevine" to reach the East.
- Why is "All-in-One" different than wax?
"All-in-One" contains no wax nor any of it?s shortcomings such as: it doesn't clean, it doesn't last, it's easily removed by gasoline, it builds up and turns yellow. Waxes (even carnauba) can turn to acid through oxidation or hydrolysis (this process is called saponification). Instead, we've created a one-step non- abrasive, long lasting, easy to use, versatile, safe and dependable acrylic alternative.
- Can I use "All-in-One" above and below the waterline of my boat?
Absolutely! Below the waterline: "All-in-One" will remove most forms of hull contamination, restore shine and color, and help retard algae growth. Sorry, but boat can?t be in the water when working on the hull. Product is not affected by salt water, and is environmentally friendly.
- Why is this product so expensive?
Granted, without seeing our products work, or having them explained properly, the initial "container" cost does seem high compared to the many cheap consumer products available. The performance, versatility and durability we have engineered into our products are the result of a no-compromise design approach. We use only the finest West German chemicals and technology, with no shortcuts in the formulation . It's false economy to buy 15 or more $3.00 to $8.00+ mediocre products that can?t do as much, last as long, or work as reliably as a single bottle of "All-in-One".
- Is KLASSE like the paint sealant the car dealer wanted to sell me with my new car?
There is no comparison between what is usually sold and any of our products. We won't point fingers, but beware of multi-year claims and read the fine print. "All-in-One" is superior to what dealers offer. You apply a better product, enhance your vehicle?s value and appearance, and save money.
HOW TO USE "ALL-IN-ONE"
More than a wax that you simply put on, let dry, and wipe off. "ALL-IN-ONE" is a real polish. A polish is a substance that both takes away and adds. The chemical cleaners combined with a little elbow grease take away oxidation and surface scratches. This in itself reveals the oils and inherent shine in the paint (clear coat is paint). The polish also adds oils for additional shine ("wet-look"). Thus, simply putting on, letting dry, wiping off will add shine but no do much taking away. Condition of the paint has more to do with how much work is involved. "ALL-IN-ONE" in itself is easy to use.
Damp cloth: a wash cloth (terry cloth wash cloth) Wet, wring out to make it damp. Do a test area first. Start with small amount (about a quarter-size) Use back & forth motions (like polishing compound), or large circular motions. Even, form pressure (not digging in). Wipe off immediately. Repeat. First shot does mostly cleaning. Second puts more acrylic down and the paint will feel softer. First time use will take the most work. Keep it up every 4-6 months. It's really simple: 15 minutes.
Quickly Detail
Put an ounce or two in a pint spray container, fill with water, and shake. Spray on, wipe off. For paint, plastic, windows, chrome. Car Wash Put a capful or two in a bucket of water and stir. Use as a car wash. Yes this really works. Try it.
Comments on technique
- Damp cloth to apply, soft cotton terry cloth to take off.
- "ALL-IN-ONE" is compatible with water. No need to dry car completely.
- More product is not better.
- Works immediately. No need to dry. If it does dry, no problem. You can do entire car and wipe off with a towel in each hand.
- Particularly bad areas can be worked on numerous times. Face cloth in one hand, soft towel in other. Rub on, wipe off, repeat until point of no return. (No need to keep using more product)
- "ALL-IN-ONE" may be applied to cloth or directly to paint.
- Can be used in sun, but much preferable to work in shade.
- Hot paint should not be touched. Cool down with hose.
- "ALL-IN-ONE" will not get rid of embedded grit (Industrial fallout) or house paint overspray.
Big Features/Benefits- Maintains shine, wash after wash.
- Does not stain rubber & plastic trim.
- Car easier to wash, dirt comes off more easily.
- Does not hold heat (like wax). Allows paint to breathe. Can be used on fresh paint next day.
- Acrylic offers protection against UV light & heat (unlike wax).
- Great clarity & depth: that deep rich "Wet-Look".
Economics
Illusion: Seems (relatively) expensive
Reality: A bargain
Use one-two ounces twice a year with no need to buy different products for different needs (separate cleaners, polishes, wax) or different products for different purposes (plastic polish, car wash, chrome polish, etc.)
Additional Information
The uniquely formulated KLASSE "ALL-IN-ONE" NON-ABRASIVE CLEANER PROTECTOR is in ONE PRODUCT an exceptional cleaner, restorer, "wax", polish and sealant. With an easy ONE-STEP application, it removes oxidized paint, old wax buildup, road tar, gasoline stains, water spots, tree sap, bird droppings and paint over-spray with excellent results, and without scratching the paint.
It then immediately seals and protects the surface with an elastic non-chip, shrink-proof, heat and scratch resistant, long lasting acrylic finish.
"ALL-IN-ONE" protects against salt water, ultraviolet rays, acid rain, industrial pollutants, rust, and corrosive elements for 6 to 8 months. Since no drying time is necessary (wipe on and wipe off), it leave no residue.
"ALL-IN-ONE" is unsurpassed for all paint (including clear coat), plexiglass, fiberglass, plastics, glass, metal surfaces, enamel, tiles, formica® and other non-porous surfaces. It is anti-static and contains no harmful ingredients which might damage surfaces, and eliminates the need for conventional waxes of any type.
KLASSE ALL-IN-ONE FOR RETAIL & PROFESSIONAL USE
Acrylic One-Step: Cleaner-Polish-Protectant Cleans: Oxidation, Tar, Sap Polishes out surface scratches & swirl marks enhances Protects with acrylic for about 6 months
Use on: All Paint - Great for clear coat Plastic - Convertible windows, wind deflectors, bug shields, etc. Fiberglass, Chrome, All Hard Surfaces
NO SILICONE, NO ABRASIVES, NO WAX, NO POLYMERS, NO TEFLON
- After I use ALL-IN-ONE, I use
- Klasse High Gloss Sealant Glaze is a highly concentrated acrylic formula glaze for new cars and oxidation-free surfaces. High Gloss Glaze provides an additional protective layer over the All-In-One with an exceptionally brilliant mirror-like shine.
High Gloss Sealant Glaze creates an elastic, non-chip, shrink-proof, heat and scratch resistant - protective seal against ultraviolet rays, salt water, acid rain and industrial pollutants for up to 12 months. Use this glaze on all paints with or without clear coats, glass, fiberglass, Plexiglass, plastics, metal surfaces, enamel, tiles, Formica and all non-porous surfaces. It is anti-static, non-abrasive and contains no ingredients harmful to paint, metal or plastic.
A lot of customers who order High Gloss Sealant from Klasse, the German giant in car care, tell us how impressed they were. You put a lot of time and effort into detailing, so your finish should always “reflect†the care you put into it. Use Klasse High Gloss Sealant to achieve optimum results, including that deep mirror shine that reflects beautifully with diamond-like facets for six months or longer. Many people who use this sealant report that they only have to put a new coat on every twelve months. Some people re-gloss every 6 months or so. Here is how using this product provides an amazingly, reflective shine:
Acrylic Formula. Unlike many sealants, this product is 100% acrylic based, and highly concentrated for a long shelf life. This formula will transform your vehicle into a stunning work of art that reflects upon how much you cherish your vehicle.
Hides and Removes Imperfections. When used in conjunction with Klasse All In One Polish, you will see scratch marks and paint discolorations disappear. This gloss hides and removes more swirls than any other brand, and provides the ultimate protection in extreme weather. One of our Colorado based customers called in to let us know how great his Klasse products work during harsh, winter months. His finish actually repelled snow and sleet which left him stunned and elated!
Pure Protection. This product is a pure, acrylic protectant. There are no cleaning or polishing agents or water in the composition of the sealant. Klasse High Gloss Sealant Glaze creates an elastic, non-chip, shrink-proof, heat and scratch resistant - protective seal against ultraviolet rays, salt water, acid rain and industrial pollutants for up to 12 months. Use this glaze on all paints with or without clear coats, glass, fiberglass, Plexiglass, plastics, metal surfaces, enamel, tiles, Formica and all non-porous surfaces. It is anti-static, non-abrasive and contains no ingredients harmful to paint, metal or plastic.
Heritage in Car Care. When you purchase Klasse, you will have peace of mind knowing you are using the highest quality products offered in the car care industry. For over twenty five years Klasse has been producing this exceptional line.
Max’s Tips
• MULTIPLE COATS will increase the clarity of the reflective shine, and deepen the overall mirror like finish.
• DAMPEN YOUR MICROFIBER PAD then apply a dime-sized amount onto the pad. Wipe in long, layered strokes and use just a little pressure, it won’t hinder the results. Let the sealant remain on the entire surface area of your vehicle as long as possible before you buff your car. Mist the surface with quick-detailing spray if it resists buffing.
• WAIT 8-12 HOURS BEFORE APPLYING additional coats of Klasse High Gloss Sealant. I recommend you let your car sit overnight and then reapply in the morning or afternoon.
16.9 oz. Made in Germany
