![]() Join Date: Jul 2004
Ok I have some parts for sale if you want photos ask and Ill send them to you.
Shipping is extra and I will combine as best I can to save you shipping. If you post to my thread in the other forum please don't repost here just post in one place. Samco sport breather hoses these are from white racing products and list at $88 a piece $150 for this pair ![]() Secondary vacuum canister located under the plenum this is brand new $130 part number 10067563 ![]() secondary injector module controller used I have both of them $250 each ![]() secondary vacuum throttle port actuators used $50 a piece still work but they are original 90's ![]() mounting brackets for above actuators $35 each Fuel pump assembly complete take out of tank unit $200 ![]() Used LT5 spark plug wires $150 Taylor spark plug wires installed once too long for my taste so I removed them $50 Throttle Position Sensor shield used $70 rear bumper moldings all 4 used $375 Left and Right timing chain tensioners "compressed" with housings $300 secondary Control Check valve (the one under the plenum) one used from 90 $25 low tire pressure sensors left front green and right rear orange from a 1990 $100 each 1991 BCM or as some call it the CCM from under the dash board taken from a Low mile 1991 ZR-1 sub 10,000 miles on this $300 1990 BCM sub 19,000 mile car $300 1990 Info center with FULL ENGINE POWER light $100 1990 LT5 engine 18,000 miles $6500 Bell housing $300 I have 2 of them 1990 Dash board skeleton id plastic frame with dash harness. includes nothing else no modules bcm radio nothing else. $400 1990 black door panels show some age but not to bad $250 for the pair 1990 Door sill covers black same thing show some wear $75 flowmaster exhaust been sitting outside for a couple of years just needs some TLC has surface corrosion around the welds and is used $350 Rear bumper crash bracing, this is what the Gas tank sits on, aluminum construction you can see it up under your bumper, if your ever in a rear end crash you will need this. $400
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. Last edited by phrogs; 09-12-2010 at 03:46 PM. |
![]() Join Date: May 2006
PM sent on CAM Position Sensor
Troy Marquis 68 L-89 #9876 - Under Restoration 69 L-88 #21214 - L-88 Tribute 70 L-46 #9516 - Top Flight 71 LT-1 #2638 71 LT-1 #5172 - Canadian Export - Top Flight 71 LS-6 #15133 - Canadian Export - Under Restoration 90 ZR-1 #338 - Restored 90 ZR-1 #890 Project Phoenix 91 ZR-1 #1255 - Triple Crown Winner 69 Firebird Project: w/ 69 L-89 Motor #24390 16 Z06 Admiral Blue/Red Interior (1 of 2) - Sold |
Ill take the vaccum seconary lines new $75
The crankshaft position sensor new. $25 secondary Control Check valve New $50 Paypal ok?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 04-24-2010 at 04:31 PM. |
I'll take the other crankshaft position sensor new $25
![]() Taylor spark plug wires installed once too long for my taste so I removed them $50 ![]() Throttle Position Sensor shield used $70 ![]() rear bumper moldings all 4 used $375 Left and Right timing chain tensioners "compressed" with housings $300 ![]() Last edited by phrogs; 09-12-2010 at 03:47 PM. |
![]() One used Left Hand cylinder head with valves, springs, retainers and keepers, No end plugs, lifters or camshafts. sold low tire pressure sensors left front green and right rear orange from a 1990 $100 each ![]() Lower rocker panels need to be painted they are dark red sold 1991 BCM or as some call it the CCM from under the dash board taken from a Low mile 1991 ZR-1 sub 10,000 miles on this $300 ![]() ***1990 BCM sub 19,000 mile car $300 Same as above photo*** 1990 Info center with FULL ENGINE POWER light $100 ![]() Last edited by phrogs; 08-01-2010 at 05:54 PM. |
1990 Air conditioning controller sold
1990 LT5 engine 18,000 miles $6500 ![]() Bell housing $300 I have 2 of them ![]() 1990 ZR-1 rear rims need refinishing sold 1990 Dash board skeleton id plastic frame with dash harness. includes nothing else no modules bcm radio nothing else. $400 ![]() Last edited by phrogs; 09-12-2010 at 03:49 PM. |
1
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. Last edited by phrogs; 05-11-2010 at 07:15 PM. |
Would not hurt John.
#10 |
Parts arrived thanks Johnny
