Old 04-24-2010   #1
phrogs
phrogs's Avatar
Default ZR-1 parts for sale April 2010
Ok I have some parts for sale if you want photos ask and Ill send them to you.
Shipping is extra and I will combine as best I can to save you shipping.
If you post to my thread in the other forum please don't repost here just post in one place.
Samco sport breather hoses these are from white racing products and list at $88 a piece $150 for this pair
Secondary vacuum canister located under the plenum this is brand new
$130 part number 10067563
secondary injector module controller used I have both of them $250 each
secondary vacuum throttle port actuators used $50 a piece still work but they are original 90's
mounting brackets for above actuators $35 each
Fuel pump assembly complete take out of tank unit $200
Used LT5 spark plug wires $150
Taylor spark plug wires installed once too long for my taste so I removed them $50
Throttle Position Sensor shield used $70
rear bumper moldings all 4 used $375
Left and Right timing chain tensioners "compressed" with housings $300
secondary Control Check valve (the one under the plenum) one used from 90 $25
low tire pressure sensors left front green and right rear orange from a 1990 $100 each
1991 BCM or as some call it the CCM from under the dash board taken from a Low mile 1991 ZR-1 sub 10,000 miles on this $300
1990 BCM sub 19,000 mile car $300
1990 Info center with FULL ENGINE POWER light $100
1990 LT5 engine 18,000 miles $6500
Bell housing $300 I have 2 of them
1990 Dash board skeleton id plastic frame with dash harness. includes nothing else no modules bcm radio nothing else.
$400
1990 black door panels show some age but not to bad $250 for the pair
1990 Door sill covers black same thing show some wear $75
flowmaster exhaust been sitting outside for a couple of years just needs some TLC has surface corrosion around the welds and is used $350
Rear bumper crash bracing, this is what the Gas tank sits on, aluminum construction you can see it up under your bumper, if your ever in a rear end crash you will need this. $400
JOHNNY P
Currently own
Old 04-24-2010   #2
Marq21
Default Re: ZR-1 parts for sale April 2010
PM sent on CAM Position Sensor
Troy Marquis
68 L-89 #9876 - Under Restoration
69 L-88 #21214 - L-88 Tribute
70 L-46 #9516 - Top Flight
71 LT-1 #2638
71 LT-1 #5172 - Canadian Export - Top Flight
71 LS-6 #15133 - Canadian Export - Under Restoration
90 ZR-1 #338 - Restored
90 ZR-1 #890 Project Phoenix
91 ZR-1 #1255 - Triple Crown Winner
69 Firebird Project: w/ 69 L-89 Motor #24390
16 Z06 Admiral Blue/Red Interior (1 of 2) - Sold
Marq21 is offline   Reply With Quote
Old 04-24-2010   #3
Ill take the vaccum seconary lines new $75
The crankshaft position sensor new. $25
secondary Control Check valve New $50
Paypal ok?
Old 04-24-2010   #4
Jagdpanzer
Jagdpanzer's Avatar
I'll take the other crankshaft position sensor new $25
Old 04-24-2010   #5
phrogs
phrogs's Avatar
Old 04-26-2010   #6
phrogs
phrogs's Avatar
One used Left Hand cylinder head with valves, springs, retainers and keepers, No end plugs, lifters or camshafts. sold
Lower rocker panels need to be painted they are dark red sold
***1990 BCM sub 19,000 mile car $300 Same as above photo***
Old 04-26-2010   #7
phrogs
phrogs's Avatar
1990 Air conditioning controller sold
1990 ZR-1 rear rims need refinishing sold
$400
Old 04-28-2010   #8
phrogs
phrogs's Avatar
1
JOHNNY P
Currently own
Old 04-28-2010   #9
Would not hurt John.
Old 04-28-2010   #10
Parts arrived thanks Johnny
