Old 05-26-2010   #1
Default A question about the Tech 1 Scanner.
Ricky was nice enough to let me borrow his Tech 1 scanner for my ABS problem but cant quite figure out how to use it.I plug it into the cig lighter,plug it into the underdash port,type in year 1991 and scroll down and select stored trouble codes and it asks for the ABS adapter.Am I missing something here?
Old 05-27-2010   #2
Default Re: A question about the Tech 1 Scanner.
Jeff, this is just a fwiw in that I'm not positive it applies to a Tech1 scanner.
On my snap-on scanner there are software modules that I plug into the scanner to do trouble shooting on the different vehicle systems. I have a general GM cartridge and a GM engine trouble shooting cartridge in the scanner when I do the DTC's for the motor controls. If I do my abs system, I need the general GM cartridge + the specific ABS cartridge plugged into the scanner before it will do any diagnostics.
Now if I want to just pull ABS trouble codes, I use my Gordon jumpers. However, if I want to run any of the tests I have to use the scanner with the ABS cartridge in the machine.
I am fairly sure that the Vertronix Tech 1 and Tech 1A scanners are the same as I keep looking for one on e-bay with a fairly complete cartridge library as the older software is sometimes hard to find.
Old 05-27-2010   #3
I think the problem is I dont have the ABS cartridge.
Old 05-27-2010   #4
I know that all the Tech 1 & 1A machines I looked at on e-bay used a software cartridge system similar to what my snap-on scanner uses....so yes if you don't have a cartridge labeled ABS, then you need to see if you can get one.
Old 05-27-2010   #5
John Boothby
John Boothby's Avatar
You need the ABS Brake cartridge p/n TK03030B for, I believe, 1988-93. Good luck finding one, I have been looking for a while. There are TK03030 cartridges all over, but I can't find the "B". Anyone out there have one would like to sell, let me know.
Old 05-27-2010   #6
Marq21
John,
I recently checked the ABS system on my car with my Tech 1 and the first thing that comes up is the "adapter" item you mentioned. This is not the software cartridge but an additional adaptor that plugs into the end of the regular Tech 1 connection that goes to the ALDL connector. From my memory this additional adaptor correctly connects to the ABS pin out on the ALDL connector. I would check that first as I am not sure your issue is the software at this point. Could be wrong, but I distinctly remember that item poping up as well. Hope that helps.
Troy
Troy Marquis
68 L-89 #9876 - Under Restoration
69 L-88 #21214 - L-88 Tribute
70 L-46 #9516 - Top Flight
71 LT-1 #2638
71 LT-1 #5172 - Canadian Export - Top Flight
71 LS-6 #15133 - Canadian Export - Under Restoration
90 ZR-1 #338 - Restored
90 ZR-1 #890 Project Phoenix
91 ZR-1 #1255 - Triple Crown Winner
69 Firebird Project: w/ 69 L-89 Motor #24390
16 Z06 Admiral Blue/Red Interior (1 of 2) - Sold
Marq21 is offline   Reply With Quote
Old 05-27-2010   #7
Your missing the ABS adapter, I think it pins out certain areas in the ALDL port. See below I have a $17 suggested solution to the problem
http://cgi.ebay.com/ebaymotors/TECH-...motiveQ5fTools
http://cgi.ebay.com/ebaymotors/GM-Ve...motiveQ5fTools
Old 05-27-2010   #8
72ZR1
you need the mass storage cartridge in tech-1 and the bosch ABS adapter plugged in to port under dash.plug tech-1 into adapter.
72ZR1 is offline   Reply With Quote
Old 05-27-2010   #9
John Boothby
To plug into the ALDL you need the 12/14 pin adaptor TA01140. I don't think that you "need" the mass storage adaptor unless you are storing data to download into a computer.
Old 05-27-2010   #10
John Boothby
By the way, whats going on with your ABS. I ask because I had a "Service ABS" light on my DIC and it turned out to be the "Lateral Accelerator" behind the radio in the dash. Pretty easy fix and not expensive!
