Old 06-17-2010   #1
rkreigh
Default Tough VA emissions - need help
time has come for VA emission again
the standards are very tough, the LSV is a 390 ci, full porting, big valves, and has the 234 cams which make it very tough
I also have the secondaries removed which reduces the "port velocity" swirl, runs off both injectors above 1% throttle
the 48 HC standard typically gets me, I'm well over it, usually around 130-150!!
I'm considering brand new cats on the car as mine are the random cats and several years old and from what I understand don't do that great a job (great flow though!!)
I'm looking to potentially get an emissions chip burned, one person even suggested a chip for M85, but I've never seen that done.
anyone pass this tough a standard with a stroker ZR-1?? don't think it's possible but any alternatives (short of moving or selling the car ) are welcome
anyone have any suggestions??? I'm coming up due in July
thanks!
Old 06-17-2010   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Tough VA emissions - need help
Ron,
I have a stock 94 chip you can borrow if you think that will help.
Might think about unpluging all of the secondary injectectors so you run just on the primaries.
Old 06-17-2010   #3
Pete
Pete's Avatar
Ron,register her at my place,drop her off i will take good care of her.
No more emission worries and won't need stinken CATS.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 06-17-2010   #4
rkreigh
Ron,
not sure the big doggie would even run on a stock chip. but it might be worth a try
thanks Pete, chicago is a bit of a commute for me!
Old 06-18-2010   #5
SharkPilot
SharkPilot's Avatar
I forgot to mention before...
My car has a Doug Rippie chip in it and it passes just fine with it in place. I have the stock chip but have never installed it. The engine is very close to stock so that probably explains a lot.
Let me know if you need help. I'm in Anaheim so I'm close by.
Sorry... posted this to the wrong thread. Oops.
SharkPilot is offline   Reply With Quote
Old 06-21-2010   #6
SoCalZR1
I feel your pain. I have a post running on the very topic, but here in Ca.
It sounds like you have a pretty hard HC limit to hit. How is the test done in Va? Is it on a "Dyno" or just in neutral at certain RPMs?
SoCalZR1 is offline   Reply With Quote
Old 06-25-2010   #7
rkreigh
on a dyno at idle 15 mph, and 25 mph
need to find some help as with this configuration I don't think I have a prayer of hitting 48 HC unless the car is tuned for E85 or something very special
an emissions chip and fresh cats might do it, but with these cams, I doubt it.
Old 07-02-2010   #8
SoCalZR1
I finally passed today, but just barely. I hit 76 on my HC and the limit was 77. NO went fine this time so finally I am good. 48 sounds hard!
