![]() Join Date: Mar 2004
My 90 is not passing smog. NO is about 800 needs to be less than 541. One problem we are seeing is the out put from the left side O2 sensor pulses negative when warmed up. The car is equipped with exempted SSW headers. Has anyone experienced anything similar?
sounds like that o2 is either stuck, meaning bad or possibly a vacumm leak...just somthing i thought. hope this helps
I should have mentioned in the first post, the offending O2 sensor had been changed, no change. Still investigating a possible vacuum problem. Still pondering the O2 sensor outputting a negative voltage.
#4 | |
![]() Join Date: Jun 2010
Mike |
Tags |
smog |
