02-14-2014 | #21 |
Re: Headers Installation...
Im still trying to find a factory set to NCRS my car. Steve offered me his to use, but I would rather purchase a set to have with the car.
It's the only Item I need to make my car Original, but like my old man says their only original once! |
02-14-2014 | #22 |
What exactly are you looking for? I'll try to keep an eye out for it.
Clint & Sherry 1994 ZR-1 White/Red #152 (sold) 1991 ZR-1 Callaway Aerobody #1332 (sold) 1990 ZR-1 Red/Red #952 (sold) 2002 Z06 Torch Red/Mod Red widebody |
02-15-2014 | #23 |
02-15-2014 | #24 |
I've got one from a 1991. Are they the same?
Jep |
02-15-2014 | #25 |
If ur looking for something after cats, an LT-4 exhaust should work.
02-16-2014 | #26 |
Anyone with PE pipes think that the exhaust controllers at the end of the pipes can be remotely controlled? Jeff? Dave?
Electronically or by vacuum?
02-16-2014 | #27 | |
Found this on the capsule itself! http://www.powereffects.com/tech.htm Jeff Last edited by Shrek; 02-16-2014 at 11:13 AM. |
02-16-2014 | #28 |
Spent :30 minutes getting 2 ex manifold bolts loose P side. Wow.
I found 2 ex manifold bolts missing on the 4-hole. This is looking like a BIG job...
02-16-2014 | #29 | |
I will say while mine was on the lift a couple of months back, it appeared the header swap would not be a simple job. You can do it though, I have confidence in you Pal! |
04-23-2014 | #30 |
Schrade
I just went through this. I certainly didn’t document the installation up to your standards though. Many of the bolts are accessible easiest from under the car with long extensions. Have a good assortment of extensions, swivels, swivel wrenches and short stubby combo wrenches. I used my ΒΌ “socket set on most bolts as mine were not that tight or corroded. The Passenger side is easiest. DR side a bit more difficult. I had to loosen the heat shield and bend it a bit on the DR side to get all the bolts off. New Header installation is much easier. Order a new dipstick tube gasket from Jerry if you haven’t already. My SW headers required that I make a dipstick relocation bracket. (I copied the basic design of Pauls bracket…. Thanks Paul!) I would bet your OBX headers will need it also. If you or anyone else needs to reinstall the AIR tubes on your headers, I have a stick of 304 – 3/8 OD Stainless tube that I have left over from my installation. What a bit@# to bend. Good Luck Darby
[I]4-cam[/I] [I]1991 ZR-1 Blk/Gry #31[/I] [I]SW Headers/Xpipe- Dynomax Muffs[/I] [I]Ported top end[/I] [I]Secondaries Removed[/I] Tune by Dominic |
Thread Tools | |
Display Modes | |
