04-25-2019 | #1 |
WTB crank sensor connextor
I am looking for the 3 wire crank sensor connector found on the Ignition Module. I can find the harness side but I want the module side connector.. thanks
Image1556229503.716517.jpg Sent from my iPhone using ZR-1 Net Registry
04-25-2019 | #2 |
Re: WTB crank sensor connextor
04-25-2019 | #3 |
Thanks but I need the IM side of the connector
04-26-2019 | #4 |
I guess I'm unclear as to what you're looking for. The connector in the link is the connector that plugs into the left rear of the module. The connector on the module is molded into the entire case.
Are you just looking for a female connector that would match the cases connector? If so, it's this one: https://theelectricaldepot.com/weath...0ae6902b383fa4 Last edited by spork2367; 04-26-2019 at 08:38 AM. |
04-26-2019 | #5 |
https://www.whiteproducts.com/fusible_link_wire.shtml
Go to the website and download online catalog. Looks like Metri-pack 1508. |
04-26-2019 | #6 | |
I have the one you posted (series 150 and I don't believe it fits.. I will check again, but if I recall it is too wide Yun, 1508 is the harness side connector, yes, it is a series 150.2 pull to seat. I have not been able to find the female mate to it, that is what I need essentially I want to plug it into the harness
04-26-2019 | #7 |
04-26-2019 | #8 | |
04-26-2019 | #9 | |
Are you looking for the female side? For your custom ignition module? |
04-26-2019 | #10 |
Yes
Thread Tools | |
Display Modes | |
