Old 02-22-2013   #20
Default Re: Repair Shop?
Originally Posted by sammy View Post
there is another map sensor under the computer ck to see if its connected . if you have a 90 .you could have the problem i had turned the key top on light lit but no secondaries .so i tried turning the key back a little and poof they worked . i just replaced the key switch with a toggle switch .
fixing the switch is easy
