Old 03-09-2014   #1
Default Re: brakes & rotors
Originally Posted by mike100 View Post
My current set up is Hawk HPS with EBC rotors (cast in the UK). The HPS dust, but this combo dissipates heat properly.
These look a lot like PowerSlot Rotors, same cadmium plating. I ran Powerslot Rotors with GrandSport Calipers and Performance Friction Z pads for a few years before I installed the 4 piston Brembos with big, hatted rotors.
It was more for the asthetics with the Fikses & LPE Aerobody than anything. The PowerSlot/GS Calipers/PerfFric-Z combination worked well for anything I ever did.
Old 03-09-2014   #2
Originally Posted by TomZR1 View Post
Jerry,i think you mean c pads from auto zone, I've been reading a lot of reviews on c pads(autozone),Wagner , hawk hps,I guess to each thier own,good not good,dusty no bite,loud.best review so far hawk hps,not going to track the car,Sunday drives,car shows, a little street racing so it must handle 0-120,120-0,every once in a while
I don't know about the "c pads" you mentioned, but do recall the pads were Performance Friction, Z-Rated. I do not know if A/Z still carries the performance Friction Line. it's been several years ago.
Re: Here's a link that lists a lot of different rotors, Hawk & Performance Friction pads. The performance Friction-Z pads are still current.
http://www.frozenrotors.com/shop-by-...ty+suspension/
Old 03-12-2014   #3
TomZR1
Here's my update after days of research hawk hps it is $159 f/r pads,rotors ended being oem gm,still had life getting them cut.plan on putting everything back this weekend.Thanks everyone for all your knowledge & expertise
TomZR1 is offline   Reply With Quote
Old 03-12-2014   #4
WVZR-1
The quality of the resurfacing is quite important - it's not a "corner store" operation usually. Equipment and the condition of the tooling are important. Having them Blanchard ground is I believe generally the preferred locally available method. Automotive machine shop that does flywheels also.
*** Don't forget your front rotors are "directional'!
