02-14-2020 | #1 |
Black Tag going into '94 Z
Sup everyone,
I've removed the Blue Tag ZF-6 from my '94 ZR-1 and i've got a question. What is the easiest way to mate the Black Tag ZF6 to the '94 ZR-1, which is set up to accept a Blue Tag unit? I'm aware of the throwout bearing ID difference between the car year models.. Is changing the Throwout Bearing the only way to get the trans in? Or is there another option since I have both trans here? Just wanting to get some experienced answers. Thanks YungEff |
02-14-2020 | #2 | |
Re: Black Tag going into '94 Z
H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
02-14-2020 | #3 |
A Black label trans with short shifter rebuilt by ZFdoc installed in 95' (No Lift Ring) 👍👍
Post 241 - Rebuilt Black Label Transmission Installed and New Driveshaft U-Joints
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-14-2020 at 09:05 PM. |
02-14-2020 | #4 |
Swap the VSS from the Blue tag to the Black tag.
Obviously the throwout bearing is different. You'll need a early model shift boot with the reverse lockout ring, it's attached to the boot itself. I put a '95 Blue tag in my '90 after the third gear synchros went out on my black tag. I found it more economical to buy a factory rebuilt transmission than rebuild my black tag. No reverse lockout ring, and I bought a ZR1 labeled T-Handle shift knob from a forum member who makes them, which I prefer over the stock shift knob. The blue label is much quieter transmission, but does make about the same amount of growling in neutral with the clutch out as the Black tag did. 'Crabs
02-15-2020 | #5 |
The obvious question is: WHY do you ask? There are pros and cons either way.
Excerpt from an article delivered by Marc Haibeck at Bowling green (date unknown by me) The serial and model tags are black up to about 1993 ½. They are blue from that point forward. Black tags units were manufactured in West Germany. The blue tag units were manufactured in Vernon Hills Illinois. There is no clear correlation for tag color and torque capacity. The model number listed on the tag specifies the torque capacity. The entire article:
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 02-19-2020 at 06:54 AM. |
02-17-2020 | #6 |
Thanks for the .PDF Paul, and thanks everyone for the responses. I was mostly wondering if the input shaft guide tube could be swapped from the blue to the black tag unit. That should allow the black tag to work with my original '94 throwout bearing, but i'm guessing it's not that simple (correct me if i'm wrong).
Anyway, i did order the '89-93 throwout bearing but I haven't Installed it. I'll be getting back to working on the car this week. YungEff |
02-18-2020 | #7 |
A '94 if original would be a 'black tag' and have a lift ring i believe. 3 I've seen were. Is the 081 'blue'? I've no idea. If you've a known good 'maybe' OE release bearing swapping the guide tube I'd think deserves some consideration.
If the 'black tag' is a '91+ you shouldn't need to be concerned about the VSS. If the 'black tag' is a '90 it will have a center connector and it would be wise to swap yours. I'd be interested in a snapshot of your service tag on the take out! Last edited by WVZR-1; 02-18-2020 at 04:28 AM. |
02-18-2020 | #8 |
Actually my ZR-1 is a '94 model with an original blue tag. However I did speak with Bill and he told me that I could swap the guide tube from my blue tag to my black tag, which will allow me to leave the original throwout bearing in.
So Im gonna do that and then install the black tag. Thanks again though to everyone who responded. YungEff |
02-18-2020 | #9 | |
How about a snapshot of the 'tag'!!! |
02-18-2020 | #10 |
Sure, here is a pic of the blue tag ZF6 I removed from my '94.
