Old 12-17-2013   #101
Default Re: 1990 Throttle hesistation
Chuck,
If you go to page 15 of the DM manual, (http://www.tunercat.com/Docs/DM32man_v400.pdf) you'll see that you can export data as a .csv file. That will allow you to look at it using .xls. Just record your throttle position session and then you can review whats happening.
Makes things much easier.
Old 12-17-2013   #102
Schrade
Originally Posted by Tyler Townsley View Post
I use a OTC 3575 ignition system simulator also known as a PRI ISS Ignition System Simulator. I bought it off ebay years ago for $130. It checks Ford, Chev and Chry dis ignition systems. What I like about it is you do not have to have the car running to check it out, you do need a scope to look at the different signal forms which is how I saw the fact that the dis was falling apart.
Tyler
Does it read out for ALL operational variables?
I have ONE, at least, which is not within spec. And without a DTC, I have to essentially see the whole operating system.
I think Windows is easier than this (and I do Linux OS). Command line interface doesn't scare me, but reading fuel trim cells - hmmm ...
I did the comma separated values data file, posts 37 - 39, this thread. Posted format didn't come out too well, and pertinent values might not appear, but I'm working on it.
Even BEFORE that, I need to know WHICH values to include in the 'Bit Data'. EGR duty cycle, and Vehicle Speed, for example, aren't necessary...
Old 12-17-2013   #103
Just attach the text file to the post or send it to me.
Old 12-18-2013   #104
tpepmeie
OK I have the same mod but I thought when Tod (I assume Marc is using Tods hack to accomplish the turn on) did the mod it turned on both injectors on start.
Tod are you out there?
Tyler
Marc does it slightly different than I do. He turns them on >0% throttle. works well either way.
Old 12-18-2013   #105
Tyler Townsley
Does it read out for ALL operational parameters?
The checker does not 'read' any sensors. It simulates the inputs to the dis module. It has an adjustment that varies the inputs from 0 throttle to 7k. You can scope the output to the coils or pull the plugs and watch the spark across the plugs.
http://thepandatrap.com/tyler/misc1/dis_3.jpg
http://thepandatrap.com/tyler/prototype1/page18.jpg
http://thepandatrap.com/tyler/prototype1/page16.jpg
Tyler
Old 12-18-2013   #106
Chuck,
Looking at what you posted, it seems like you get all the parameters in the data stream. So yeah, just record that and export it as a .csv file.
Old 12-19-2013   #107
Schrade
This will be over NO time soon. It's a comedy of errorS, or a Greek Tragedy - depending on who's holding the wrench.
Got everything bolted back up, ready to manipulate the throttle stop bolt for DM recording, and lo and behold, the coolant by-pass line had jumped the casting ridge on the A/C compressor again - bound under the primary butterfly shaft.
I was cursing.
Got it un-zipped, freed up the line in 3 minutes, back together. Then the last TB extension bolt fell out.
It is no where to be found.
Then I REALLY started cursing.
And the D side coolant manifold elbow is leaking - can't tell if it's a loose gasket, or ruptured elbow.
Next up; drain the coolant from the cross-over pipe lower, pull it, and pull the serpentine belt, to get a better field of view. Hopefully, the bolt will show without having to break down block front accessories...
This is getting really discouraging.
Old 12-19-2013   #108
Franke
Can you probe with your magnet to see if you can catch it> Like goin' fishing.
Old 12-20-2013   #109
Default Switch Throttle Bodies
What I do because I have spares of everything for three corvettes (two Zs) is switch from suspect bad component to known good component. Then leave good component on if that is the case and when time is available .....fix bad component if fixable
This involves little time, NO immediate component testing.........and NO DISCOURAGEMENT...........usually
It is amazing the remote fishing holes below an LT5 and even more amazing the oddball fish that lurk there
I have found injectors from previous maintenance there for example.
Old 12-20-2013   #110
Schrade
Power Steering pump separation? 4 bolts?
3B-12, FSM.
4 bolts? Dream on, butterfingers...
