02-17-2012 | #121 |
Re: Exhaust for max performance.
The reason I asked was if you're going to have to run cats over there then will it matter if your mufflers flow more than them. I'm running random technology 3 inch in and out cats.
They're supposed to flow 600 cfm. So whether my mufflers flow 2000 cfm or 1000 cfm they shouldn't hurt performance since they both flow more then the cats. If you're going to end up in the same boat as me, and have to run cats, maybe the dynomax vt's would be a viable option. Just thinking out loud.
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 |
02-17-2012 | #122 | |
But, you're probably right and not sure what flow is needed where it won't matter how much more you have. For all we know, the amount from the VTs are enough for a 350 motor and like you said if there is a choke point before the mufflers it should not matter so good point. The problem with the VTs according to Dynomax catalog is there is no single in with dual out configuration and the single in and single out is offset for the inlet side so not sure how to make that work with existing system having a center inlet if trying direct replacement.
03-16-2012 | #123 |
Why do I always have to be different? Well, instead of going with the Dynomax Ultra Flo 17228 with dual tips, I went with Dynomax 17220 ($79.90 with free shipping from Amazon.com) Ultra Flo 3" in/out" single tip and using Pypes Challenger tips ($58/pair due to flaw with no slot for clamp on and I want to weld it on anyway) for a different look. The flow is a little different since no split inside the muffler, but my split will be in the tips so curious to see the difference in sound.
17228 flow is 1900 SCFM, Loss free HP 864 (single)/1728 (dual) and the 17220 is 1800 SCFM, Loss free HP 818 (single)/1636 (dual) Muffler next to tip 3" straight through Tip from the outlet view Tip from the inlet view Anyway, I can't wait to install these and I will post more photos and video with sound clip, then to dyno tune once headers and xpipe back on at the same time. Right now still doing all the fine tuning (data logging and bin files back and forth by email) to try emissions testing again with the stock crap on. I can't wait to have the B&B gen 3s chopped off and put these babies on. Craig
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 Last edited by HAWAIIZR-1; 03-16-2012 at 05:53 PM. |
03-16-2012 | #124 |
I'll be waiting to see and hear what these babies are like.
03-16-2012 | #125 |
I like the look. Is the muffler stainless or steel shell?
03-16-2012 | #126 |
Thanks Dom! I'll be sure to post and give feedback.
Brett, According to Dynomax the Ultra Flo welded are: Stainless steel construction for lifelong protection. 100-percent Welded design for maximum durability. Dyno proven to flow up to 2,000 SCFM and support up to 2,000 horsepower. Straight-through design ensures unrestricted exhaust flow and reduces back pressure. CRF Technology absorbs unwanted interior resonance while maintaining a deep performance tone. I could not find what kind of stainless, but I thought I saw somewhere else 409 stainless. I like these welded muffler much better than the seamed style. After hearing Dom's and all the videos on You Tube, I personally do agree that Ultra Flos sound the best and allow for the most HP based on folks that have tested them or compared with others. Craig
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 Last edited by HAWAIIZR-1; 03-16-2012 at 06:47 PM. |
03-16-2012 | #127 |
Craig, I had the 17220 on my 89.. that car had a modded 350 with Miniram, cam headers etc
In this clip this was the exhaust: 1.75" headers 3" Magnaflow cats 3" Resonator with internal X ( custom Bassani piece) pair of 17220s LT1 modded tips http://dl.dropbox.com/u/19662692/exhaust.wmv This clip is 10 meg, might want to right click, save as http://dl.dropbox.com/u/19662692/DX6490.mov You can also hear the Trans rattle in the longer video
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 03-16-2012 at 09:56 PM. |
03-16-2012 | #128 |
very nice sounding car. love a car with a good cam in it . what did it sound like inside the car cruizing on the freeway ?????
03-17-2012 | #129 | |
Not sure how different the LT5 w/SGC Stage I cams will sound with 2.00" SW headers, no cats, SW x-pipe, pair of 17220s and Pypes tips. I hope the it eliminates or reduces drone.......ha, ha! Like Pete said, I don't want no old geezer exhaust and this should help keep me awake as well as no need for stereo (how much weight can I save by pulling all of that out? just kidding, but I never turn on my stereo anyway). Craig
03-17-2012 | #130 |
Craig , are you going to use the factory pipes? either way Please take some pictures..
