#171 | |
![]() Was either of those removals necessary? Now given I can remove the Plenum with Air Horn and TB attached in 10 minutes Removing Plenum (including the 10 minute Plenum Removal) ![]() I will post a Link in -Solutions- In the ZR-1 ELECTRICAL Section as the First Tip under BATTERY AND CHARGING ![]() After you post this Video in YOUR OWN Post or I will just leave it here. Left Click on Photo to watch Schrade Remove his............................................... Alternator ![]() I always had my Plenum Off so never tried removing the Alternator by itself without removing anything else.....besides if I had to.......just looking at it...prolly would not have tried it anyway without removing the Plenum ![]() Chuckie needs some Chili to warm up.... ![]() I did remove the Heads one time with engine in car and after Heads were removed I could almost lift out by hand the rest. So pulled the rest simply because Timing the Engine is a lot simpler engine out of car.
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-24-2014 at 12:07 AM. |
#172 | ||
How do you embed video in your post? Quote:
![]() ![]() =================================== Now where's Dom here - when I start with DM logging here, do I need to have the Sec power key on? Or is it already defaulted on, with Marc's chip for sec vac delete?
#173 |
I copy your video to my puter and then upload same to Photobucket....then copy IMG Codes and paste into post.
Or more Simply for you now......Right Click on my imbedded Video copy of your video and Left Click Properties....Copy URL Address and paste into your post as IMG Code.... There....now the secret is out ![]() ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-25-2014 at 01:27 AM. |
#174 |
Looks like someone HAS done removal without plenum pull, but there's always room for improvement...
install vid... Is this bracket the same on my '90, as on Geof180's LT5??? Sure wish someone would have mentioned it to me here... ![]() Anyway, temps got above freezing, thanks to a little Global Warming, and I played with DM a little here. Started this thing up, and it fired IMMEDIATELY ![]() Once it went CL, I did a vid showing incremental increases with the throttle stop screw, and DM readout in the foreground. She's running perfect, although it still shows the hesitation once it goes above 1.6% TO - although it doesn't manifest as a 'hesitation'; more likely just irregular RPM's... Working on .csv formatted file now here........................
#175 |
![]() ![]() ![]() Join Date: May 2007
I have done it with just the air horn removal. It's easier with the TB out of the way but I only had an Air Horn gasket when my Alternator crapped out.
Yes the smaller alt bracket is the same from MY90 - MY95
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-25-2014 at 07:25 PM. |
#176 |
I cut a slot into the bracket bolted between the IH and the back of the alternator.
#177 | |
Not sure I'm followin' ya' on a slot on that rear bracket - what was hitting the bracket when you did it? Bat+ post? And how do I send ya' the DM .csv file? And what values can I DELETE here: Rec Num Frame Time Time Stamp 2nd Inj Fuel TPS % TPS Volts STerm-LC STerm-RC Fuel Trim Cell IAC Pos Idle RPM Ign Volts Inj A FPW Inj B FPW Inj BPW D-TPS Inj BPW D-TPS Inj BPW Left Inj BPW Right Inj DC Left Inj DC Right Knock Count Left O2 mV LO2 CCNT LTerm-LC LTerm-LP LTerm-RC LTerm-RP MAP PT Vacuum Right O2 mV RO2 CCNT And any others I need to INCLUDE???
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 01-25-2014 at 07:54 PM. |
#178 | |
Just send the entire .csv file.
The black 90d bracket with the IH bolt thru it. Can't move the bracket without completely removing the IH BOLT and that won't happen because it runs into the plenum. Quote:
#179 |
This vid done with SLOW incremental increases in throttle, using throttle stop screw. Note the erratic reading at about 1:57...
http://www.youtube.com/watch?v=ahqv0vs1Y1o http://www.youtube.com/watch?v=8qDwChs9KMw
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 02-09-2014 at 09:37 AM. |
#180 |
![]() Join Date: May 2013
I see what you are saying. I'm a bit concerned about the right bank fuel (ST/LT) trim not changing much. I wonder if your right bank O2 sensor is lazy or malfunctioning.
