Old 08-27-2006   #11
evl_twn
evl_twn's Avatar
Default Re: lumbar pump repair
Fixed it tonight. I went out and got some Lexol to clean and protect the seats, so I went ahead and pulled the driver's side seat out (better to clean it that way, too ) and had a look inside. I should have taken some pics, but what I found was a bracket was actually missing that holds the right side inner side bolster in place, and the return spring was loose inside the seat. The plate sort of hinges, with the air bladder sandwiched in between. I'm not sure how it came apart, or what happened to the bracket, but I ended up making one out of aluminum stock I had laying around. The inner bolster was not even in the correct "hinged" position, it was just loose inside the seat, and so was the air bladder. Kinda makes me wonder what happened to it. All is better with my interior now though, all clean and the seats even work
evl_twn is offline   Reply With Quote
Old 08-27-2006   #12
GOOD JOB AND NICE DETAILED FOLLOW UP FOR OTHERS
Old 08-27-2006   #13
evl_twn
evl_twn's Avatar
Well, I should have taken some pics while I was in there to help someone else out if they're having problems, too. Here's the seat section of the microfiche from Kurt White's page, the bracket that was missing is part #45, it keeps the moving plate (23) from sliding off the fixed plate (24), and the air bladder (9) also is fixed to the moving plate by sliding over the tabs that it hinges on.
http://i.b5z.net/i/u/46804/i/databas...01994-1995.jpg
Old 08-28-2006   #14
Glad you got it fixed..
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
