Old 08-22-2004   #11
Wayne
Wayne's Avatar
Default
FU2 Posted: Sat Aug 21, 2004 7:36 pm Post subject:
High NOX ? Are you guy's using the stock chip ?
Hi FUZ
The first time I went in I did not have my stock chip in and though that could be the problem so went home and put stock chip in. I Went right back to the smog ststion and this time it was way better on the NOx just not better enough.
Wayne is offline   Reply With Quote
Old 08-24-2004   #12
Default
OK. Now you may want to pull the EGR valve and make sure it is clean and working correctly. Next , How many mile's are on the car ?
High NOX usually mean's :
1-Chip
2-EGR
3-Cat's going out
Old 08-26-2004   #13
Wayne
Wayne's Avatar
Default
1-Chip
2-EGR
3-Cat's going out
_____________________________
Thanks RU2
Now I have something to look at.
Car has 45,000
Old 08-26-2004   #14
Default
No EGR valve on the 92's.
Old 01-27-2005   #15
Black Rocket
Default
Zoral or Wayne, I just purchased a Black '91 from the Net and as a California resident am concerned about the Smog Check. The car came with only an aftermarket chip. I live near Sacramento and was wondering if I could borrow your stock chip to pass somg when you are done with it?
Thanks, Bruce.
Black Rocket is offline   Reply With Quote
