#1 | |
-Andrew |
Good to know, I went ahead and ordered a pair from RockAuto as well. Good price too, paid $89 delivered. I figure if nothing else it's time they get changed out on my 21yr old car!
Let us know how the shimming goes. I have the same issue as you, the steering shaft is like 1mm away from the header pipe. Everytime I turn right I can hear the engine touching the shaft. H ![]() |
#3 | ||
A question regarding Motor Mounts came up and I refreshed an old thread with some additional information regarding Motor Mounts
![]() Oreilly Auto 2902 Summit Racing 2902 Ecklers Motor Mounts Quote:
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 04-16-2014 at 12:31 PM. |
Anchor 2902. I ordered a private label and a regular inventory closeout, they were the same part but one had a made in india sticker, the other did not, but had INDIA stamped debossed on the rubber portion of the mount.
Hans, an update for you... today I unbolted the lower nuts from the motor mounts, and jacked up the driver's side of the motor. I slipped 2 body/alignment shims in around the stud (I chose 1/8 inch each, for a total of 1/4 inch), and lowered the motor back down, and tightened the nuts once again. I gained approximately 3/16 to 1/4 inch of clearance between the #1 primary and the steering shaft.
I'd like to find a shim with a larger surface area, but I suppose this has got to be better than the interference that was present before. |
Update: After taking the car for a drive, the mount settled a little, leaving about 1/16" or so of clearance -- which was enough to make me notice just how much vibration was being transmitted through the car due to the interference. It's much quieter and smoother now.
#8 | |
H ![]() |
#9 |
BTW Andrew... did you have to remove or at least loosen the C-Beam?
H ![]() |
#10 |
When I initially did the job, yes, I removed the headers, h-pipe, and the rest of the exhaust, and removed the c-beam so that I could have as much freedom as possible to jack up the motor. When I later shimmed the driver's side mount, I did not have to re-loosen the C-beam.
