Old 03-28-2012   #11
secondchance
Default Re: A few ECM Questions...
Did the MY 94 and MY 95 ZR-1 get the aluminum ECM covers like the LT1 and LT4 received later in 96. Or did all Zs stay with the same plastic ECM?
My 94 has same ECM box as earlier ones minus plastic cover. I believe 95 was the same.
Old 03-28-2012   #12
So,,, its in an aluminum cover? GC
Old 03-28-2012   #13
VetteVet
VetteVet's Avatar
Ron,
If you're looking for the female connectors (I assume to make a conversion harness), I have searched and have not found anything out there. If you were to take a bad ECM and desolder the connectors from the ECM main board, you would have something that would plug into the engine harness, but would not really be suitable for a conversion harness.
If that's not where you're headed, I apologize. Through my research, I have come to the conclusion that Delphi never made any female versions of those connectors other than the ones used for the ECM circuit boards. You could give Mike, the owner of EFI Connection, a call. He may be able to help.
Jep
Old 03-28-2012   #14
RHanselman
RHanselman's Avatar
Jep,
Your on the mark...
Thanks,
Ron
RHanselman is offline   Reply With Quote
Old 03-28-2012   #15
RHanselman
RHanselman's Avatar
I believe all the ZR-1 ECM's have the same basic black steal case... Only the covers and decals are different from 93 up...
Cheers,
RH
Old 03-28-2012   #16
Originally Posted by VetteVet View Post
Ron,
Jep
Yes but for a conversion harness, he could use 2 sets of PCB connectors and wire them in a ECM box, then create another set to plug in to the box then the new ECM
just a thought
Old 03-28-2012   #17
VetteMed
I think he means the wiring cover, not the case of the ECM itself.
Old 04-07-2012   #18
RHanselman
RHanselman's Avatar
Originally Posted by limey View Post
The LT5 ECM's are a much thicker case than the L98/LT1
Kurt,
You wouldn't have a part number for the connecter would you?
