Old 07-17-2014   #11
Fully Vetted
Fully Vetted's Avatar
Default Re: Antenna Mast Replace
Did you see the Blue Beast?
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 07-17-2014   #12
Spartan1510
No. But I didn't go in the back. Maybe when I pick up the car.
Spartan1510 is offline   Reply With Quote
Old 07-17-2014   #13
Demps
Demps's Avatar
Saw it when Corey tuned my car. New gears?
Ted
Old 07-18-2014   #14
Fully Vetted
Yes. Gears (3.90's), clutch (SPEC Stage 2+) and exhaust (Corsa). He was going to heat cycle the gears a few times over the weekend. Should be ready next week sometime.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 07-19-2014   #15
It should come out once the motor is on and the nut is removed.Getting it back in the body takes some time but one person can do it.How I did mine:With door closed turn the key to forward-on position but not start the to the off position.Turn on the stereo to activate the antenna and let it run until it stops,position the mast in place,push the cable down into the body but dont force it.With the cable in position open the door,this with kill the accessory feature and the antenna will activate pulling the cable into the body.It will take a few tries to get it right,if you dont get it the first time just turn on the stereo and the mast will come out.After I replaced the mast about a year ago now the reception sucks so will have to replace the whole thing at some point.Ive got a new 93 antenna,the wiring isn't the same as my 91 so Ill have to figure that out.Keep in mind that if the cable in the mast breaks and leaves a piece in the body the has to come apart.
