#11 | ||
#12 |
Unless the brake pedal is unhooked you have definitely lost the master cylinder. Any other failure would still have some braking.
The good news is you are here talking about it. The other good news is outside of bleeding it's a pretty easy job. Be sure to keep the brake fluid away from your paint. All for now, - Jeff |
#13 | |
I guess it will be a good time to do the lines, and paint the calipers? |
#14 | |
Make a project out of it while you are there. I always bench bleed the master before install
#15 |
Has anyone bought a master cylinder lately? I'm looking at Advance Auto Parts and Rockauto. Advance auto has a ton listed on their site. They are all reman parts, but I don't know which one would be correct for my application.
#16 |
![]() Join Date: Feb 2011
I don't think the brake parts are ZR-1 specific outside of the J55 option. J55 ended up being standard on all 95 and 96's so all the parts except for the special Zr-1 brake booster should be obtainable from common sources.
#17 |
![]() Join Date: Apr 2004
Last one I got was from NAPA casting had some minor differences but worked out great.
#18 |
There are a ton of Master Cylinders listed on Advance Auto Parts website. They all vary in price as well.
I noticed last night that the front reservoir for brake fluid was empty. I guess that confirms the bad MC? |
#19 |
Yes, since you already verfied no leaking at the calipers.
#20 |
That fluid went somewhere, If you can not find any leaks be sure to check the booster I have seen when the seals blow out it let the fluid drain into it. If not look to see if it ran down the front of the booster where the master cylinder bolts on.
