Old 06-02-2015   #11
Billy Mild
Default Re: Changing Back 2 spark plugs
Maybe someone else wants to chime in, but I stopped using anti-seize on the plugs. There was a thread about this a while ago. I found that anti-seize allows the plugs to loosen. Been using a dab of oil on the threads instead.
I have been doing this for years on cars. My old 944 Turbo was an all aluminum engine as well and I never had an issue changing plugs at the 15,000 mile interval.
Old 06-02-2015   #12
Bob Eyres
Just did that job Bill, here's what worked for me.
Swivel spark plug socket then 3/8" extender, 3" long (to get above the hole), then another swivel to work a good angle, then a longer extension so you don't break your back leaning over.
It worked for me.
Old 06-03-2015   #13
Jim Nolan
Oops! I meant 3/8 to 1/4 stepdown.
Old 06-03-2015   #14
Hib Halverson
Here's what you need for #8.
3/8-drive, plug socket with integral universal and either an internal magnet or sponge retainer.
3/8-drive, one-inch extension
3/8-drive universal joint.
Stick all that on a long extension. It goes easily down the plug well. With the socket on the plug, the point at which the extension swivels on the top u-joint is just above the edge of the plug well.
I use a 30-in extension and a 3/8-drive T-handle to loosen and tighten plugs on an LT5.
Also, I use taper seat plugs which interfaces with the head on the taper which is how the plug seals. I use DuPont Krytox antiseize on the plug threads only.
For plugs, for the last 15 years or so, I've used the Denso IT-22 which is a range colder than the original LT5 plug (FR-1LS).
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 06-04-2015   #15
8cam
Guys this isn't hard. A 3" extension and a u-joint and out it comes. Never had a problem, and at least on my 90 there is plenty of clearance. Leave the rubber washer in the socket and it will pull the plug right out.
8cam is offline   Reply With Quote
