Old 12-04-2015   #1
BigIke
Default Jerry's Gaskets - RAM Clutch Review
#1616 began slipping soon after an alternator replacement and the discovery of a few hidden ponies when a manifold vacuum leak was fixed and the secondaries were tied open. Deciding between a stock replacement and the RAM was a hard one; my deciding factor was the level of support Jerry provides us (the correct alternator, after many incorrect units was my experience). Also, our stock parts are getting scarce; an upgrade to the clutch now should make the assembly 'future proof'. I love the clutch, i would buy again and again...
-She's back on the road, driving in rush hour traffic daily!
Install was straight forward, and I've written up a detailed how-to... I went with the 1000$ kit, which is supplied with the least expensive, 13lb flywheel. Prior to disassembly I thought a light weight flywheel because of the slight clattering i could hear at idle, more so when I'd shut it off. I was mistaken, it was the dual mass, all components were in decent condition, save the disc.
-13lb flywheel
Going back together, I measured the depth of the pilot bushing, the new bushing was installed to the same depth. Make sure the clutch is perfectly aligned when torqueing the pressure plate. The anti-rotation pin (installed at 7 O'clock - looking at the input shaft) needs the bolt flats ground down. A 1-1/8 to 1-1/4 hole must be drilled in the bellhousing @ 5 o'clock, this will allow access to align the hydraulic release bearing (HRB) with the anti-rotation pin.
-The flats that are facing out board need to be ground flat, the washer as well.
-Through this hole you can see the HRB, anti-rotation pin
Remove the clutch fork pivot stud, doing so will allow the 45 deg HRB fittings to fit in the bellhousing. When installing the 45's, clock them to roughly 130-140 deg down. When the HRB is aligned with the pin, the fittings will point towards the clutch fork hole. Install the bleed hose on the top fitting. Dress the input shaft bearing housing with wetted (WD40/mineral spirits) emery clothe, Install the three spacers on the input shaft bearing housing. Assemble tranny; flush master cylinder, connect and bleed the HRB.
-This photo show the fittings at 90 deg, note the hoses are touching the bellhousing. Also note, the fork stud is removed.
I drove for 467 miles before I really go into it. For about 300 miles there was a 'clutchy' smell, however, absolutely zero slippage. It will roast the tires like never before, and a swear, the 1st gear torque is going to break the rear suspension. Pros and Cons:
Pros
1. 1/3rd the clutch effort... Seriously, my 10 year old Not Boy 1 could operate this thing with ease.
2. Excellent touch.
3. Crazy fast reving.
4. There is a lot more power, it isn't BS or Magic... Just power.
5. The flywheel rattles, it rattles a lot, and i love it.
6. Amazing grip...
Cons
1. The flywheel rattles, it rattles a lot, and my wife hates it... LOL
2. Without the extra rotating mass, taking off can make you look like a stick shift amateur. I've stalled the car five times... I don't stall cars... It will also die if the A/C on and i blip the throttle (fix will be an increase of 100 RPM when it's tuned).
So the thing rattles, similar to a wore out LS1. If you don't like the rattle, go with a heavier flywheel. I used ZFDocs recommended Castrol 10w-60 2,200 ML. My fill plug was stuck... I filled through the vent hole at the top forward portion of the tranny.
https://static.xx.fbcdn.net/rsrc.php...PAXP-deijE.gif
Jay
THANKS JERRY!!!!
