Old 01-17-2007   #11
Usa1-Zr1
Usa1-Zr1's Avatar
Default Re: Coolant to Plenum Delete
5 -years with my by-pass and havent had a pocket yet except for breakfest Do the by-pass it great not getting coolant everwhere when ya pull the plenum..
Usa1-Zr1 is offline   Reply With Quote
Old 01-17-2007   #12
jonszr1
jonszr1's Avatar
that type of by pass ok but he was talk ing about plugging the tubes commong out of the plenum. and that scares me . cause you could get pockets their i think ?
Old 02-03-2007   #13
HADI-ZR1
can you show me more in details picture of your mod. plzz. thanks!
Old 02-25-2007   #14
ojb
ojb's Avatar
Hi there,
I have a 1990 ZR-1 and my previous owner installed power plates. They should keep the plenum cooler and
also block the coolant passages into the plenum.
My engine looks like this. You see the air bleeding hoses are missing, but I have bleeding screws on the coolant output.
I also have a Jaguar V12 which had a heavy engine damage cause of overheating.
Therefore I am also very very afraid of air pockets.
I found a picture on the internet where someone had also the coolant blocked to the plenum but
installed special air bleeding hoses.
This seems to me a very clever solution. Wht do you think about it and has someone a idea how and
where get those hoses?
Thank you in advance.
Greetings from Munich, Bavaria.
Oli
PS: I found the original thread of locobob, who did the mod with the hoses:
http://forums.corvetteforum.com/show...plenum+coolant
ojb is offline   Reply With Quote
Old 02-28-2007   #15
haber rj
I installed the plenium plates when I put my new injectors in and I didn't block off the TB. I didn't know at that time that you could do that, is this going cause me any problems, I don't really care if it doesn't do much for the peformance as long as no harm will come to the motor. i am not taking the plenium off again unless I have to.
haber rj
haber rj is offline   Reply With Quote
