Old 04-28-2017   #11
Roadster
Roadster's Avatar
Default Re: Minimum Air Idle Adjustment
Just removed the TB, on my way to get the 7mm hex bolt...making progress....
Sent from my SM-G935P using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 08-07-2021   #12
BlackZR1
BlackZR1's Avatar
I know this is an old thread but just went through this procedure and it worked great for me so wanted to give a shout out to Dom and Phil for the procedure and tips. Thanks!
The only exception I ran into is that the 25mm long Hex head idle stop screw was a bit long in my case and the head was barely clearing one of the TB brackets when the throttles are almost full open so I used a 20mm long screw.
When I started, my IAC counts were 30 at idle. Now they are 10-12.
Thanks again.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
Old 08-08-2021   #13
Thanks again.
Thanks Roger. Do you note any difference in idle or driving around?
Old 08-08-2021   #14
BlackZR1
BlackZR1's Avatar
A couple weeks ago the car died a couple of times when coming to a stop which never happened before. I cleaned the IAC pintle and seat. Checked IAC counts at idle - was 30 which is high. Good news, high counts suggests no vacuum leaks but high counts at 650 rpm means the primary throttle blade opening at idle could be a tad too small which could explain stall when coming to a stop.
After finishing the idle setup yesterday, went for a drive today and drove perfectly - idle did not drop too low when taking my foot off the pedal and never died after an hour of driving and probably 2 dozen stops.
One more thing I will mention is that my original throttle stop screw measured 7.6mm extension from the mounting tab. I installed the new Hex head screw about 8mm extension (because I wanted more air through primary blade/less IAC counts) and this put me within a half-turn of my final adjustment.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Old 06-24-2024   #15
scorp508
Digging up an old thread as I work through some stalling issues when coming to a stop before I go grab a data log. I realize this may be a "it depends" question, but is there a rough number of IAC steps one should expect to see with foot off the throttle at idle? I see BlackZR1 went from ~30 to 10-12 after following the procedure.
Thank you.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
Old 06-24-2024   #16
Originally Posted by Roadster View Post
Will get the 7mm hex head bolt later in the AM.
So the best way to do this is leave the throttle cable assembly attached to the TB, and remove as one unit, and just work on the TB in the engine compartment.
Another member also suggested the same.....thx....
U want enough IAC steps so ECM has room to ?catch? idle drop, but not too many steps to where most of idle air is coming thru IAC opening. I typically shoot for 10-15 steps. One other step I do is to modify the IAC Min Air table in the calibration to match what the actual IAC counts are in operation.
Old 06-24-2024   #17
scorp508
On a cold start when the desired idle is still 1250 it looks like IAC is at 110.
Once warm and desired idle of 850 the steps are around 30-40.
Old 06-25-2024   #18
scorp508
It would appear I don't have this table as the only IAC related thing in my XDF is "IAC Position vs. Coolant Temp". My understanding (possibly wrong) is the IAC vs. CTS is only used during Open Loop. However, open loop does seem to be where most though not all of my stall issues take place.
Looks like it is in my best interests to go through the IAC procedure anyway and see where I land.
Currently it is mostly the same as the stock BMCB with a couple changes.
Code:
Deg C / Deg F / Steps
-40   / -40   / 95
-16   /   3   / 78 (Stock BCMB value is 90)
  8   /  46   / 51 (Stock BCMB value is 32)
 32   /  90   / 24 (Stock BCMB value is 12)
 56   / 133   / 10
 80   / 176   / 10
104   / 219   / 13
128   / 262   / 25
152   / 306   / 45
Is this table read as a base value, or in other words, "no less than this many steps" when the table is being utilized?
Old 07-30-2024   #19
scorp508
One small note for any future people. I was having trouble with this procedure as I didn't use the correct ALDL pin combo on my 94 to extend the pintle. I needed to use pins 4 & 6 to use the Service Engine Soon light to flash. Only this combo fully extended the IAC pintle on my 94. The other ALDL pin combos for CCM on the digital dash or the flashing Service Ride Control light do not work to extend it.
Old 07-30-2024   #20
tpepmeie
I feel like I knew this at one time, but was this a model year change, regarding the ALDL pin combination for the IaC? If so, when did it change?
