Old 12-16-2019   #11
Hib Halverson
Default Re: Finally got my Z to behave on Track!
Originally Posted by cbaclawski View Post
It's a 90. Based on my research so far, I'm leaning in the c5 direction. looks like all I'd need is an adapter bracket and c5 rotors. (and possibly spacers and longer studs - I have the "salad shooter" front wheels...
Thank you Dynomite for those links, I really don't like drilled or slotted rotors, but it's great information anyway!
Keep in mind that while the C5 brakes are an improvement over C4, from a tracking perspective, it won't be by much. You may find that after all that work and cost of installing the C5 brake discs and calipers, you didn't gain much brake performance, especially if your tracking involves long runs. Also, on C5 brakes, the only difference between a C5 and a C5 Z06 brake is red caliper paint and, if they have OE brake pads, more aggressive front pads.
If you're a serious trackrat with your ZR1, I'd be looking for something a bit more substantial in the front. It may cost more but the return on investment will be greater. You, also, need to add front brake ducts.
As for drilled/slotted rotors, today, drilled rotors are just for looks. The vast majority of modern brake pads do not have trouble with outgassing, which drilled rotors were invented to address. Also, all those holes decrease the brake disc's heat sinking and, unless the drilling is done right, they also can cause cracking. Slotted rotors are a better choice.
Lastly, in re: your second post, about finding a leak in the system. Before I'd sink time and money in to a C5 brake upgrade, I'd bleed the system, stick '96 GS front calipers on the car (a bolt-on), add some brake ducts in front and go track test.
Depending on how you are on brakes during tracking, you could find just having no leaks, GS calipers and better front brake cooling is adequate enough for the tracking you do.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 12-17-2019   #12
gtcollins@maxnet.co.nz
What would be a good setup for tracking the ZR-1
Regards Glen
Sent from my SM-G973F using ZR-1 Net Registry mobile app
Old 12-17-2019   #13
cbaclawski
The Z is not my primary track car, but at this point the track is where I drive it most, primarily due to the installed 1 piece seats and 6 pt harnesses.(does that even make sense?)
I agree that the c5 calipers would be a modest upgrade at best, but since they would be free and I needed new pads anyway, the only extra cost/work would be a $150 adaptor plate and new rotors. I totally agree with you regarding drilled/slotted rotors. At this point they are pretty much just for looks and eating brake pads while wearing out faster...
Since I first posted, I ordered a new set (front and rear) of Hawk DTC-70 pads, and a replacement j55 caliper from Autozone. The caliper arrived in 48 hrs, but the Pads took about a week to arrive(yesterday). I had decided to wait for the pads to arrive to install the new caliper and pads at the same time. After waiting patiently for the pads to arrive, I went out after work yesterday and despite the caliper box from Autozone having the correct part # on it, inside was a jl9 caliper, which obviously didn't fit around the installed rotor.
So now I am back to square one. Upon close inspection of the banjo bolt, I can see the threads are worn, I can slide it a good 1/4 inch into the caliper without turning it, and it won't hold any torque at any depth. A replacement bolt seems to "bite", but I am concerned about the internal threads on the caliper so I don't want to just change bolts and hope for the best. About an hour ago I ordered the correct m10-1.0 thread tap. When it arrives I'll try to revive the threads on the caliper, and if it feels good, I'm going to run with it(and maybe some Loctite). If I mess it up worse, I'll just order another caliper and hope they send the right one this time.
Since the c5 calipers are free, and the effort/cost to install them seems minimal, I'll probably do the swap next time I need front pads.
I'll definitely thoroughly bleed the system once I'm satisfied with the components.(I always do before every track day in any car...)
I've really struggled getting this car to be driveable on track. I'm really close, and think it will be pretty darn quick once I get it 100% sorted...
Thanks for your advice, (and giving me a reason to tell my caliper story!)
Curt
cbaclawski is offline   Reply With Quote
Old 12-25-2019   #14
VikingTrad3r
VikingTrad3r's Avatar
Curt
Curt, i took my zr1 to the track and my 86 4+3 that was stock with better rubber and c4 grandsport brakes handled far better.
I'd like to make my primary zr1 the track car but it was all over the place and im not sure if it was the extra weight or the old tires or the alignment.
what have you done to get to your z so close to be a monster on the track?
do you have a thread that shares what you have done?
Merry Christmas!
VikingTrad3r
Calgary, Canada
1991 ZR1 # 888 - daily drive whenever possible
1991 ZR1 engine from unknown sn.
1990 Z51 zf6 being built into narrow body ZR1 racer
1987 z52 auto - sold
1986 'z31' 4+3 - sold
1985 Z51 auto - sold
VikingTrad3r is offline   Reply With Quote
Old 12-25-2019   #15
cbaclawski
Merry Christmas!
The car already had the Lingenfelter 368 package so power was never an issue. I started with seats and harnesses, a 3.73 rear, and had it sent up to Marc Haibeck for a thorough mechanical sorting and a new tune.
Then the Master Cylinder failed on it's maiden run(spoiler: I put it in a tire wall), so I replaced the master, installed the DRM bias spring, and replaced all 4 calipers. Hawk DTC-70 pads all around, and motul 660 fluid. (In addition to substantial front end body work).
Next time out it was still virtually undriveable, so I had it aligned. Turns out it was way off.
3rd try, it was much better but still really loose, so I bought better rear tires from a member here (RussMcb).
4th try, Finally the car handled great, but the leaky front caliper described in this thread caused poor braking performance that deteriorated throughout the day. - New caliper should be here tomorrow...
I'm a regular Track Rat, but have a few cars I track much more frequently, so it's taken me a while to get to this point...
Here are a couple threads I made with more detail, and some great advice from others: (in chronological order)
http://www.zr1.net/forum/showthread.php?t=29988
http://www.zr1.net/forum/showthread.php?t=30024
http://www.zr1.net/forum/showthread.php?t=30535
http://www.zr1.net/forum/showthread.php?t=30741
Merry Xmas!!!
Curt
