Old 04-19-2020   #11
MuRCieLaGo
Default Re: Car back from body shop - horn buttons don't work
Originally Posted by Vette Guy View Post
That side doesn't look broken. It should ever so lightly twist into the connector receptacle down in the center of the steering column. It's been years since I fixed mine, so I'm providing my best recollection. I'm searching for a photo for where it should be connected....
Only found one for a C5, but the idea is the same.
I know the cable goes into the hole but something has to be preventing it from coming out... I really don't know.
MuRCieLaGo is offline   Reply With Quote
Old 04-19-2020   #12
ZWILD1
ZWILD1's Avatar
You really need to pickup a copy of the GM FSM and the 8A electrical section booklet that contains all the cars electrical schematics. I had a situation with my 77 Trans Am tilt wheel. The guts are pretty much the same. The horn plugged in the same way. I took a picture of a couple pages out of the FSM. I need to get section 8-A myself.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
Old 04-19-2020   #13
ZWILD1
ZWILD1's Avatar
Sorry about the two pics. I rotated them and they flipped back when I posted them. In figure 5 part 7 is the part that the horn spring goes into. This maintains contact as you turn the steering wheel through it's full motion. Section 8-A really gets into the possible wiring issues. The owner of my car had one but was moving and couldn't find it. He gave me a complete Service Manual set on CD but I can't get it to come up on my pc. Hope the views of the column help out. The basic function was the same on my 77 T/A. They haven't really changed that much from then to our 90-95 cars.
Old 04-19-2020   #14
Vette Guy
Vette Guy's Avatar
The connector has a ‘tab’ on the side, which should insert into the ‘key way’, once it bottoms out in the receptacle, gently twist it clockwise so the nub or tab goes into a retaining slot - similar to an automotive bulb.
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is offline   Reply With Quote
Old 04-20-2020   #15
MuRCieLaGo
Alright that's the information I was looking for!
I found the problem. The clip is broken. The broken piece was still laying there when I removed the steering wheel. I'm confident it could be glued, if only I knew how to remove it... Do you guys think it's safe to remove that retaining clip? The big sticker kind of scares me.
Old 04-20-2020   #16
Vette Guy
Vette Guy's Avatar
Default Car back from body shop - horn buttons don't work
Can you use a set of tweezers and carefully gel superglue it in place?
Mark Horner
91 ZR-1 #2016
Old 04-20-2020   #17
MuRCieLaGo
Haha, I thought about it! It's very tempting, but pretty risky too. There's not much room. I'm lucky enough to have the broken piece in hand...
EDIT: Alright, I manage to glue it in place. I'm going to put a second coat of glue tomorrow morning. Hopefully it'll be good!
Old 04-21-2020   #18
Vette Guy
Vette Guy's Avatar
Keep us posted!
Mark Horner
91 ZR-1 #2016
Old 04-21-2020   #19
MuRCieLaGo
Keep us posted!
Thanks for asking,
I used Permatex Plastic Welder. It worked for 1 day, then it failed again. I glued it again and I also glued the black plastic part to the (broken) retainer. Hopefully it'll work this time.
Old 04-22-2020   #20
So the plastic cam nub is broken off. It needs to make constant contact so push in an very small wedge a slither of wood or paper in the hole to retain it into position. It’s the ghetto method but it works, GC
