#11 | |
![]() Join Date: Jan 2004
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
#12 |
#13 | |
![]() Join Date: Dec 2003
#14 |
Well the mystery continues... Marc tells me that the crankshaft oil plugs are too big to make it past the oil pan windage tray. So not sure what to make of the plug I found. Did it come from somewhere else on the engine? Was it already laying in the oil drain pan from some other project and I didn't notice it? Do I need to put down the crack pipe? I guess before I start tearing things apart I should drive the car a bit with its fresh oil and new filter and see what my oil pressure looks like.
#15 |
Could be a plug from one fo the cylinder heads located in the cam chain space that seals off the end of the lifter oil gallery drilling Image1607639563.955562.jpg
#16 | |
![]() Join Date: Aug 2006
Jagdpanzer said something about divine intervention by Corvette God. Or, something like that. ![]() |
#17 |
Hard for me see to it, does the plug have drill hole in it? Not from the rod journal if it does.
#18 |
I was thinking it could have been a cam plug from the rear of the cams, but I just measured one from a 1991 and it seems to be .5 inch. that is weird? I just looked a bare block and can't find anything like that....
John |
#19 |
No drill hole in the plug. The plug measures .525 across the threads, and Mark Haibeck is telling me that nothing bigger than about .25 can get through the oil pan windage tray to the bottom of the oil pan where the drain hole is. I haven't checked to see if it fits through the drain plug hole but it should just barely as the drain plug bolt specs as a 5/8's
So that leaves the following possibilities: The plug is unrelated and was sitting in the drain pan already and I failed to notice it. The plug fell into the drain pan from somewhere else on the engine My oil pan windage tray is either bent or modified in such a manner that the plug made it through to the bottom. I took it out for about a 15 minute drive. On start up and for about the first 5 minutes I'm getting really strong oil pressure, like 65-70psi. Once its good and warmed up I'm seeing maybe 25-30psi after idling for a minute but I'm seeing more like 60psi when I get on the gas. I finally found the FSM oil pressure specs, they list minimum hot idle oil pressure as 12psi... so perhaps I'm worrying way too much about this. But its odd that it's suddenly lower than it used to read, and its odd that it corresponded with finding that plug in the pan.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 Last edited by Locobob; 12-13-2020 at 03:54 PM. |
#20 |
Since you are now not sure.......I will add another possibility......
The Dash Gauge Oil Pressure Sensor and I had one that all of a sudden showed lower oil pressure..... after replacement oil pressure was fine (normal) at all Temperatures and RPMs ![]() ![]() In general the NPT diameter of a plug is 1/4" larger than the NPT size..... The oil pressure loss depends on where the "open" 1/4 NPT plug is located in the oil path. And depends on which oil path is involved.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-17-2020 at 10:03 AM. |
