Old 4 Weeks Ago   #11
jrd1990zr1
jrd1990zr1's Avatar
Default Re: 1990 AC question
Originally Posted by Young1 View Post
There are kits out there.
New compressor
New dryer
New expansion valve
New Schroeder valves and O rings throughout.
All lines and condensor and evaporator have to be thoroughly flushed because R12 oil and R134 are not compatable.
Who do you trust to remove the plenum?
I spoke with Marc H. He tells me the compressor, accumulator/dryer, orifice tube and O-rings are compatible with R134A. He also said the lines did not need to be flushed. Just need to evacuate the system, the mineral oil remains in the bottom of the accumulator and doesn't mix with the R-134A. I have evacuated the system and it is holding vacuum. I need to change the high side (AC 15-30419) and low side (GM 15-30420) Schrader ports and add 8 oz. of GM 88901445 PAG oil and then charge with R132A.
I trust no one to remove the plenum, only me.
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 4 Weeks Ago   #12
jrd1990zr1
jrd1990zr1's Avatar
Originally Posted by WARP TEN View Post
I had Marc Haibeck convert my'93 to R134 many years ago. He said, per GM's directive, no A/C equipment had to be changed, just change to fittings and fully evacuate the system. You might check with him on how to do it. --Bob
Thanks Bob. You are correct. I spoke with Marc and will do the conversion myself as soon as the parts arrive.
