Old 05-15-2024   #11
mikey435
Default Re: Help with code 43 and 55
Originally Posted by Will69camaro View Post
Had the same recently with mine with code 43 only. Did it by chance happen after driving and it being at operating temp a while and shutting off and restarting? Mine has done it a few times and it?s gone away. FSM points to it being a knock sensor. I just picked up a new one but have yet to install it.
If you don?t have a FSM I can snap a pic of the code 55 as well to help.
Yes it did it after being hot shut down for a bit and then restarted I?ll definitely check knock sensor
mikey435 is offline   Reply With Quote
Old 05-15-2024   #12
Will69camaro
Will69camaro's Avatar
That?s what mine has been doing for the knock sensor code. It says in the manual it runs a test and if it fails it sets the light. I got a sensor, just gotta get under it and see if it?s the connector, loose, or just replace it.
1992 #422 - 100k+ mi. Stock with coil overs
1969 Camaro - restomod w/ 1000+ rwhp.
1969 C10 - LS2 / 4l80e
Will69camaro is offline   Reply With Quote
