#11 |
Be careful cleaning the TB, if you clean the "dag" off the secondary butterflies, you'll probably get a high idle. That's what happened to mine.
#12 | |
The "Black Magic Goo" that causes a high idle. I'm hesitant to spray carb cleaner into the TB for fear of messing this stuff up. TomC |
#13 |
![]() Join Date: Dec 2004
This is just a fwiw on the "dag"......I used STP throttle body cleaner....not carb cleaner...on my T/B when I had my stuff apart and the T/B cleaner didn't do anything to the DAG. I was careful not to aim at it when spraying and I mostly used cotton balls soaked with the stuff to clean up the bores & t-plates by gently wipping till I got all the soot or whatever to come clean. It took a bit of time but was well worth the effort as my T/B came out very clean and the DAG was unharmed.
![]() Tom
