Old 05-10-2009   #11
WVZR-1
Default Re: Starter question
Steve,
No that doesn't mean it "won't" crank but the Nippendenso starter really likes to see 12V. What I meant is with good cables, good connections and a battery that is at or near 100% charge it (the starter) should certainly operate.
Nippendenso is the "manufacturer" of the starter assembly.
Since the starter isn't an "easy/quick" install I believe I'd start first at the battery and work my way toward the starter to confirm the "entire" starter circuit is 100%.
You don't mention miles?
If your battery and starter circuit are 100% maybe you really do need a "repair/rebuild". I'd do it "local" though! What you might pay in shipping from a US vendor should nearly cover a repair if it's minor (contacts, brushes, plunger etc). There's nothing "special" regarding the build of the starter. The rebuild/repair facility "will have" the parts for the repair! A one day repair easy for the shop!
Old 05-11-2009   #12
stedi
stedi's Avatar
Thanks for all the help.
My car has ±60 000 miles. Battery is brand new energizer. I'll perform a few tests to try to pinpoint problem and will post updates. I have to do my injectors soon so I have to pull the plenum anyway, might as well send the starter out to get checked.
Steve
stedi is offline   Reply With Quote
Old 05-11-2009   #13
VetteMed
Good info in this thread. Glad this came up before I need it!
Old 05-12-2009   #14
bldavis11
Nothing to do with starters... I've had enough ""'s though!
bldavis11 is offline   Reply With Quote
Old 05-12-2009   #15
rebuilt my Starter Solenoid tonight..
Will try it out tomorrow as it got late here
