Closed Thread
Old 07-06-2011   #21
VetteMed
Default Re: Motor mount swap questions
Update: After taking the car for a drive, the mount settled a little, leaving about 1/16" or so of clearance -- which was enough to make me notice just how much vibration was being transmitted through the car due to the interference. It's much quieter and smoother now.
VetteMed is offline
Old 07-07-2011   #22
Ccmano
Cool, my mounts are on their way... now I just need some time to install them.
H
Ccmano is offline
Old 07-10-2011   #23
Ccmano
BTW Andrew... did you have to remove or at least loosen the C-Beam?
H
Ccmano is offline
Old 07-10-2011   #24
VetteMed
H
When I initially did the job, yes, I removed the headers, h-pipe, and the rest of the exhaust, and removed the c-beam so that I could have as much freedom as possible to jack up the motor. When I later shimmed the driver's side mount, I did not have to re-loosen the C-beam.
VetteMed is offline
Old 07-11-2011   #25
Hog
Whats the NVH like at WOT with the new mount? I did up some custom rubberized miunts for the Caddy and they did transfer a bit more NVH into the cabin but only under WOT conditions.
NVH=Noise Vibration Harshness
peace
Hog
Hog is offline
Old 07-11-2011   #26
VetteMed
peace
Hog
Well, it's much less, BUT that's comparing to the prior situation where the #1 primary tube was sitting on the steering shaft. So it's not applicable to most people's situations.The OEM mounts were hard as a rock, aside from being cracked, so I can't imagine they were dampening too much NVH anymore.
-Andrew
VetteMed is offline
Old 04-16-2014   #27
Default Re: Engine mount source
A question regarding Motor Mounts came up and I refreshed an old thread with some additional information regarding Motor Mounts
Oreilly Auto 2902
Summit Racing 2902
Ecklers Motor Mounts
Good to know -- looks like the same part as the Anchor unit, but who knows.
Anchor 2902, I ordered a private label and a regular inventory closeout, they were the same part but one had a made in india sticker, the other did not, but had INDIA stamped debossed on the rubber portion of the mount.
If buying from Rockauto , the Rockauto catalog is wrong - it lists the L98 mount as the right part for the 90-91 ZR-1, but you need to look up the PN for the LT1 or the later ZR-1 to find the right 2902 part.
I pulled the headers off today, and removed the motor mounts. Here's what the original 20 year old mounts look like, next to the aftermarket new mounts. Anchor 2902. I ordered a private label and a regular inventory closeout, they were the same part but one had a made in india sticker, the other did not, but had INDIA stamped debossed on the rubber portion of the mount.
The OEM mounts are made in Japan, the aftermarket mounts are made in India. Quality seems OK, but on the mount I used for the passenger side, a little massaging with Mr. Angle Grinder was necessary for proper fit. The tube which slides into the bracket on the block, was a few mm too long, requiring some trimming.
Dynomite is offline
Old 04-16-2014   #28
VetteMed
A blast from the past...
VetteMed is offline
Old 04-16-2014   #29
Blue Flame Restorations
Hey there, Andrew! good to see you posting. Hope all is well!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Blue Flame Restorations is offline
Old 04-16-2014   #30
VetteMed
Hey guys, yeah, I still pop in every now and then, waiting to see if my old Z ever turns up...
VetteMed is offline
Closed Thread
