Old 07-27-2013   #21
Cal55
Default Re: Exhaust Manifold Stud Oil Leak
Originally Posted by 1991ZR1 View Post
I haven't driven the car since January but this is how things went.
I put the driver side center stud back in with RTV sealant. If I had to do this job again, I think it could be done without removing the manifold. I would try backing all the bolts out and move the manifold away from the head as I remove the center nut. That would give more working space.
After I finished the driver side, I worked on the passenger side. It was much easier. I did not have to remove the manifold or any of the bolts. I did remove the check valve from the AIR tubes though.
After I finished both sides, I started up the car and let it run. After it warmed up, both sides started smoking. I just let it run and eventually all the smoking stopped.
Last week I started up the car again and let it run. There was no smoke from the driver side and a very light smoke from the passenger side which stopped after a short time.
I would have to assume there was some residual oil and the RTV on the studs repaired the problem.
I looked at the passenger side manifold stud and there is oil residue on it and the manifold. How did you remove the check valve from the AIR tube and the stud? It's a tight fit getting a wrench in there. I was able to get an open wrench in there but didn't have enough leverage to even loosen it. I also noticed some frayed wiring going to the front shock to change the ride mode, but that's another issue.
Any help is appreciated.
Thanks,
Joe
Cal55 is offline   Reply With Quote
Old 07-27-2013   #22
Cal55
Cam sensors can leak also from D/S
Thanks for the reply, I'll keep that in mind. My leak right now is on the passenger side, leaking from the exhaust manifold stud and the grommet on top possibly.
Joe
Old 07-27-2013   #23
1991ZR1
I don't remember which, but it was either an open end wrench or a short adjustable wrench. Most likely it as the open end wrench for the leverage at least to get it loose.
1991ZR1 is offline   Reply With Quote
Old 07-28-2013   #24
Cal55
Thanks, I guess I'll have to put another nut on the stud to lock the other one in place to remove the stud. If anyone has any tricks or suggestions in doing this I'd appreciate hearing them.
Joe
Old 07-28-2013   #25
Sometimes if you are lucky the stud will back out when you turn the nut....I was not so lucky...be patient.
Old 07-28-2013   #26
Cal55
That would be nice! I didn't work on it today, hopefully next weekend. Thanks for the reply!
Joe
Old 08-05-2013   #27
5ABI VT
I'm curious what do the manifold bolts look like? I'm doing a hurst and beam plates and took a peek up there.. On the rear most bolts there is one missing.. And in inside what looks like a bolt hole on the manifold I can see a flat head screw 'head' of a smaller bolt...
Old 08-06-2013   #28
1991ZR1
The factory did not put bolts in all of the holes. The bolts don't look like anything special but they are non-magnetic. They go through a short spacer tube between the bolt head and the exhaust flange.
I don't know what you mean by inside.
