#21 | |
![]() Join Date: Nov 2011
#22 |
![]() Join Date: Jan 2004
On the AC/Heater head unit, hold the Up and Down Fan Buttons until a -00- appears. Then use the Up or Down button to change the number to -16. Hit the center Fan button. The AC/Heater display will now show the engine coolant temperature in Celsius. In my experience, with an aluminum radiator and 180 degree thermostat, it should stabilize somewhere around 90-95 degrees C.
#23 | |
#24 | |
On the 95' you can press GAUGES on Dash and get Digital Readout of Oil Temperature and Coolant Temperature in deg F on the SPEEDO Cluster (I think where TRIP Information is shown as I recall). Pretty Cool I would say ![]() And YES.....the Coolant Temperature on my 95' stabilizes right around 90-95 deg C on a 90+ deg day with a Fluidyne Radiator installed ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-03-2016 at 12:35 AM. |
