Old 09-15-2019   #21
Default Re: Sharp clicking from passenger rear half shaft area.
Leave it alone..........next time if it becomes a nuisance.......put some anti-sieze on the axle spline.....that worked for me
Old 09-16-2019   #22
billschroeder5842
billschroeder5842's Avatar
Thanks! Will do!
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 09-30-2019   #23
billschroeder5842
Originally Posted by Ls7/Ls9 Test Engineer View Post
Hello all,
The root cause was found to be a loose axle nut on the passenger side. Bought a new nut and re torqued +10% and the issue is now gone. Thanks to everyone for all of the help. It’s greatly appreciated.
Where did you find the nut? I called all the "big" parts houses and they don't have anything (back ordered) for 45 days.
Is this/could this be a hardware store item? If so, do you have size specs?
Thanks!
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
Old 10-12-2019   #24
billschroeder5842
I (Finally) found a set. Davies Corvette (corvetteparts.com)in Davies Florida. They have them in stock #646030 for about $25 I got both sides for new washers, nuts, star and cotter pins, delivered on Thursday.
I swapped them this morning before all the college football begins. I torqued to 190ish. I went for a quick ride on a route that typically gets my rear axle sounding like a Rice Krispy treat. So far all quiet but I'll take it out for an extended ride this afternoon.
So, other than new, what makes the new set quieter than the original set that appears to be in good condition?
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
Old 10-12-2019   #25
Jagdpanzer
Jagdpanzer's Avatar
Look for Dorman Spindle Lock Nut Kit 5101 at your local auto parts store.
They run around 8 bucks each
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 11-12-2019   #26
mrand
I wonder if the loose nut caused my right rear bearing / hub assembly to go bad... didn't notice noises until this summer - less than 75k miles. Put it up on stands and found the right rear wheel would move quite a bit.
Finally pulled the rotor off last weekend and found the nut was just more than FINGER TIGHT!
There is a huge amount of play in the hub assembly on that side compared to the other, and have a replacement in hand... hopefully next weekend I can get it off!
Marc Randolph
1991 #1334 Blk/Gray
mrand is offline   Reply With Quote
Old 11-12-2019   #27
lfalzarano
I agree that the loose nut contributed the failure.
Old 11-16-2019   #28
mrand
[/url]
After thinking about it more, I'm not so sure. The nut simply retains the half-shaft, keeping it engaged in the splines. The hub (and bearings) are held in place with the three bolts to the suspension system.
Marc Randolph
1991 #1334 Blk/Gray
