Old 10-29-2005   #21
1990 quasar blue
Default Re: ZR-1 Headers
Header pix http://www.acsvette.com/headers.html
cats http://www.martelbrothers.com/menu_search.php pn703000
header completion kit http://www.zr1products.com/products.html
ceramic coating http://www.swaintech.com/header.html#price
Old 10-30-2005   #22
bike01
hey, thanks for the links, great looking set of headers.
Anybody had the inside as well as the outside of the headers coated before ?
Might be a stupid question, but somebody told me you should do both.
bike01 is offline   Reply With Quote
Old 10-30-2005   #23
cuisinartvette
Had other headers coated inside and out and it definitely works as far as heat goes. No experience with Z headers yet.
Old 10-30-2005   #24
GregCrowe
Do the SSW headers come with all necessary bolts, hardware, O2 senser extensions, etc? ............... or do you need to buy the header installation kit referenced above?
GregCrowe is offline   Reply With Quote
Old 10-30-2005   #25
Jeffvette
Greg, you have to buy the header extension kit, and also be prepared to modify your dipstick tube. I advise buying a new one from GM to work on.
Old 10-30-2005   #26
Patton
Patton's Avatar
Hey Jeff,
What needs to be done to the tube?
Patton is offline   Reply With Quote
Old 10-30-2005   #27
Jeffvette
Tab needs to be welded on in a different location.
Old 10-30-2005   #28
Patton
Patton's Avatar
Ahhhh, i see. Jesus that was a fast response.
Thanks!
Old 10-30-2005   #29
Locobob
You'll need a new set of header gaskets too. You can use many of the stock header bolts if you want, however some will not clear due to the spacer. I used ordinary 10mm hex bolts from the hardware store, sized a bit shorter to eliminate the length of the stock spacers.
Robert
