Old 09-02-2010   #21
TFENT
Default Re: New option for fuel pump replacement
Originally Posted by VetteMed View Post
That's the easier approach, for sure... and you get a new sending unit with it. I went the Bosch route because my faith in the reliability of some of the so-called ACDelco pumps was shaken by my bad experience. Others have had better luck...
What are the concerns with the AC Delco pumps?
TFENT is offline   Reply With Quote
Old 09-02-2010   #22
VetteMed
http://zr1.net/forum/showthread.php?t=9763&page=2
That should explain a little... some folks get pretty heated and defensive when I bring up the issue, but when you are buying so-called ACDelco parts, it's best to check on the return policy beforehand... there's lots of "white box" parts out there, some may be legitimate ACDelco parts, but I have my doubts about some. The vendor in question in my case was Partsladi on ebay, who is no longer in business...
Old 09-02-2010   #23
TFENT
This is from a GM dealership and is a genuine AC Delco part. Is there some concern with this part??
Old 09-02-2010   #24
VetteMed
Probably not, but....
Old 09-02-2010   #25
TFENT
So basically just make sure its NOT made in China right??
Bottom line for me here is when I crack open the tank and take the old unit out and its covered in rust I want to replace it with a new unit. I just dont know what I am going to find. Car is a 1990 with 32K on it. been sitting around a longgggggg time.
Old 09-02-2010   #26
VetteMed
There's plenty of legitimate Delco parts being made in China nowadays. There's no guarantees on quality... but at least with a proper return policy / warranty you may sleep a little better at night. The Bosch pumps are made in Brazil, FWIW.
Old 07-10-2012   #27
Blue Flame Restorations
Did the same fuel pump install today. Very easy to cut the relief in the holster. Used the same Bosch 69225 pumps. Runs great.
NOTE:
AIRTEX fuel pumps suck. Lasted about a month. Lesson learned......
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 07-10-2012   #28
VetteMed
Good stuff, Brett!
Old 07-10-2012   #29
Thanks for your write-up on this option. Really appreciate it.
Old 07-10-2012   #30
VetteMed
Glad it helped you!
