Old 07-18-2013   #31
Default Re: SPAL FANS and 2 ROW DEWITT'S TECH Notes
May know soon as Dom and I have here close to a final tune.
Old 06-02-2015   #32
Billy Mild
Default Re: Wtb Dewitt's radiator and spal fans
I have the Ron Davis in my ZR-1
The Ron Davis is a racing radiator that has 5 cores as compared to the stock 2 core. As a "racing radiator" it performs best at racing speeds where air velocity is high. Being thicker, actually makes it more resistant to air flow than the 2 core radiator.
A simple but effective modification that yields significant results, is to drill 3 or 4 holes in the thermostat flange, just inside of the seal contact area. This modification reduces back-pressure for coolant passing through the radiator & thermostat and therefore allows more flow coolant through the radiator, instead of the bypass. Bypassed coolant means hotter temps.
I strongly suggest you perform the t-stat modification before spending a lot of time & money on expensive radiators and fans.
As a side note, the only way to insure the stock radiator is as effective as it can be.... is to remove it and insure all the gravel & debris is removed and the vanes are reasonably straight.
What is this Thermostat mod that can be done?
Thanks,
Jeff
Old 06-03-2015   #33
secondchance
Thanks,
Jeff
I think the thermostat mod mentioned is drilling 1/8" hole/holes on the thermostat flange. I drilled three 1/8" holes at first. This worked fine during the summer months. However, once it got cold coolant temp wouldn't go above 150. So, I switched to another thermostat with just one 1/8" hole. This reduced interstate cruising coolant temp in summer from 208 to 213 (depending on 5th or 6th gear) down to 196 plus/minus and during the winter around 180 to 185.
