Old 11-08-2013   #31
Default Re: Problems
Mr haibeck and Mr White sell the correct sponge corners. Dont use scotch brite. ive heard horror stories if they break down. Heard mind you never seen a result. GC
Concur....I have changed that old photo as we speak as I have switched to Marc's Cam Cover Filters on both my 90' and 91' some time ago
Old 11-08-2013   #32
Z06scentair
Z06scentair's Avatar
Talked with Marc today and he convinced me to pull the plenum and add extra heat sink paste to the ignition module. I only installed past to the intake and I would rather air-to-caution and pull the plenum and re paste the ignition module as well.
If anyone has a bad ignition module they would donor up, I would like to give to a friend of mine to play with and see if he can study it to find out more about it. This guy is double engineer from Yale. If he does figure it out then we may be able to repair bad modules in the future.
Z06scentair is offline   Reply With Quote
Old 11-08-2013   #33
Z06scentair
Originally Posted by rhipsher View Post
Check the IH bolts to make sure they have not backed out. I know for a fact that we put brand new gaskets on when I put the new injectors in. I believe the IH mount bolts are suppose to be 20 foot pounds. That could explain the coolant puddle.
Rhipsher
You are correct the bolts were loose and that was the cause for the coolant leak....all is good now with that. now it will be on to the oil filled spark plug tunnel!
Old 11-08-2013   #34
Z06scentair
'SEEMS' to be good? Hmmm... bad word - 'seems'. How's she idling in Closed Loop? Do you do scan software for the car?
I dont do software very well.... maybe when you come for the visit, you can do that for me It runs good very smooth and the idle after a few seconds is around 800 rpms. I need to check the voltage on the tps as I had remove it.....goof up installing the tps bracket on the TB. Car was wide open at initial startup. Yeah that was scary!
Didn't find a vacuum leak but I will do me best in the morning when I remove the intake again to place more heat sink paste after the conversation with Marc Hailbeck this afternoon.
Old 11-08-2013   #35
Originally Posted by Z06scentair View Post
Talked with Mark today and he convinced me to pull the plenum and add extra heat sink paste to the ignition module. I only installed past to the intake and I would rather air-to-caution and pull the plenum and re paste the ignition module as well.
Marc has a picture of an ignition module sans the epoxy. He may possibly provide a better pic than the one on the website. A bad ignition module won't really help. Because of the environment IMs were to live in, there's really no way to disassemble one. Maybe your friend can engineer a different IM we could use w current ECM but incorporate other features like support for CnP or CoP.
Old 11-09-2013   #36
Rhipsher
Would be interested in what Marc said about the oil in the spark plug area?
Just in case it happens to me
Old 11-09-2013   #37
Z06scentair
If I can find one he can study, he would be glad to offer up his services!
This cat is so smart, you ask what time it is? He tells you how to build a watch...better have a half hour to blow.
Old 11-10-2013   #38
Z06scentair
The Infl Rest light has been on since the previous owner had the car. Today I decided to correct the code 26 which is the passanger side airbag sensor.
This sensor is mounted behind/under the blower fan assembly. Removed the inner fender, rocker panel, and side panel. I could just see the sensor up in there hiding. First step was to unhook the battery positive and negitive. Removed the front 13mm bolt no sweat. The rear 10mm was a little tougher.
I took a 10mm 3/8 drive socket and slide it back and onto the bolt removing it, and then pulling the sensor out. I then scotchbrighted the back of the sensor and frame ground mounting hole. Applied di-electric grease to both parts.
Hooked the battery back up and cleared the code 26.....and a code 12 flashed. Started the car and the Infl Rest light went out. Only light that is on now is the FULL POWER ON
The total job took about two hours!
