Old 10-24-2022   #31
secondchance
Default Re: Oil Pressure Switch
Originally Posted by mmkkpro View Post
Man, you guys ROCK. My 1990 just did this. No way to get to it from below, so from the top I go. I unplugged the switch and the connector is full of oil. Ordered one from Jerry a few minutes ago. Figure I will modify my sensor socket and may even try the wire trick. I took my motor mount nuts off, but engine will not budge, afraid to jack it up too hard. Thank you guys for all the ideas, it's a giant help.
Paitience and make sure the motor is cool. May the force be with you!
Old 10-29-2022   #32
mmkkpro
mmkkpro's Avatar
My wife and I just got done with said switch. Did not remove anything or jack up the engine. My wife went in above the lower radiator hose with her small hands. I bought a short sensor socket from Amazon , and a open end 3/4 wrench. I tried but my hands just would not fit. It took about an hour or so to finish it. Thank you to my wife and you guys for all the information.
mmkkpro is offline   Reply With Quote
Old 11-11-2022   #33
blue4:2
My wife have small hands too !
She did the job in 20 minutes
Sent from my moto g(8) power using ZR-1 Net Registry mobile app
blue4:2 is offline   Reply With Quote
Old 11-12-2022   #34
Attachment 18811
You have a wonderful wife! Mine wouldn't even know how to open the hood. --Bob
Old 11-12-2022   #35
blue4:2
Well.I opened the hood and showed her the position of the sensor and handed her the tools
Old 12-25-2023   #36
EdCruz320
I installed this oil pressure switch today. This thread was very helpful - especially the hint about removing the wheel and middle fender liner panel. I tried using a 27 mm socket but couldn't get it to work. I rummaged around my toolbox and found an actual 3/8 drive oil sensor socket which made the job possible with a regular 3/8 ratchet.
Thanks all!
EdCruz320 is offline   Reply With Quote
Old 12-28-2023   #37
Starman
Starman's Avatar
The Ares socket is a must, standard 26mm deep socket is too long. Removed the mounting bolts for the heater lines and got in there with a bent handle 3/8? socket wrench. Got the old one out laying across the engine and got the new one started that way by hand. Went in over the lower radiator hose, would be much easier with hose removed, check for leaks for sure if replacing radiator hoses.
Starman is offline   Reply With Quote
Old 01-01-2024   #38
Young1
Young1's Avatar
I bought two oil pressure switch sockets on Amazon. Cut them and welded them to be deep enough to go over that TALL sensor.
Steve Young
Second Owner
SOLD
SOLD
