View Poll Results: How many miles are on your Z?
0-20k 27 18.37%
20-40k 44 29.93%
40-60k 28 19.05%
60-80k 17 11.56%
80-100k 12 8.16%
100k+ 23 15.65%
Multiple Choice Poll. Voters: 147. You may not vote on this poll
Old 01-21-2020   #31
Default Re: Mileage
90'........45,000.....#72
90'........61,000.....#3032 (Last 90' sold to public)
90'........80,000.....#2067
91'........53,000.....#1427 (500 hp)
95'........93,000.....#186 (Double Dunn Heads)
All Have:
C4 Beam Plates, Billet Aluminum Pulleys (Alternator, Water Pump, Power Steering), Carter Bling, Oil Cooler SS Braided Hoses, TB Coolant Blocked, New 180 deg Thermostat, New Radiator Hoses, Debree Screen, Haibeck Chips (91 and 87 Octain), New Aluminum Radiator, New Charcoal Canister, Starter Relay, Reconditioned Starter, Battery Disconnect, Full Power Key Reconditioned, INFL REST Sensor Re-installed, New Linkage for Secondary Port Throttles, New Secondary Vacuum System (95’ from Jerry), New BKRSEIX Spark Plugs, 10W40 Amsoil Engine Oil, 10W60 Castrol Transmission Oil, 75W90 Mobile 1 Differential Oil and Differential Drain Plug, New Serpentine Belt, New Hood Strut, New Hatch Struts.
Exception:
The 91' has Secondaries Eliminated.
Old 01-21-2020   #32
Vetman
Vetman's Avatar
Default Re: Mileage
1990 # 2441 78,000. Stock except Marc’s chip. Runs sweet and smooth. Purchased in 2012 with 60,000.
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 01-21-2020   #33
Default Re: Mileage
Originally Posted by spork2367 View Post
You can select multiple if you have more than one car.
explain???
Old 01-22-2020   #34
spork2367
Default Re: Mileage
explain???
When you originally answer the poll you can select multiple choices for cars with different mileage. If you have two cars in the same mileage bracket you can't select that. I could have doubled the choices for two car owners, but I didn't want to over complicate it.
Old 01-22-2020   #35
indy91zr1
Default Re: Mileage
91 42k
indy91zr1 is offline   Reply With Quote
Old 01-23-2020   #36
BlackSheepz
Default Re: Mileage
1990 #2530 ---- 31837 as she sleeps for the Winter.
Bought in 2015 and driven cross country from Original owner with 25,777 on the clock.
--Marc
1990 ZR-1 #2530
Gone but not forgotten:
1988 Z52 4+3
1992 LT1 6 speed
BlackSheepz is offline   Reply With Quote
Old 01-23-2020   #37
902066
Default Re: Mileage
1990 Bought in 2,000 w/4800 miles.
Today has 13,400. Soon I'll be driving it a lot more often. When my son takes it over in another 10 years, it won't look brand new anymore.
902066 is offline   Reply With Quote
Old 01-23-2020   #38
ghlkal
ghlkal's Avatar
Default Re: Mileage
1990 #2180 -- 71K
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 01-29-2020   #39
Flyman 27
Flyman 27's Avatar
Default Re: Mileage
1991 # 1935 70k miles. 500 Haibeck package
[SIGPIC][/SIGPIC]
91-#1935 Black/black & gray, Haibeck 500
Cams by Pete
Flyman 27 is offline   Reply With Quote
Old 01-29-2020   #40
tccrab
tccrab's Avatar
Default Re: Mileage
1990 #792 13,300 miles.
Haibec Chip, Flowmaster exhaust
