01-11-2010 | #41 |
Re: Engine Cleaning
Yep I'm in Rancho Cucamonga.
You could always come out to our detail clinic at Stillen Performance... I'll be posting the info here tomorrow.
[CENTER][B]USE COUPON CODE: [SIZE="3"][COLOR="Red"]ZR1[/COLOR][/SIZE] TO RECEIVE 10% OFF YOUR NEXT ORDER AT [url]www.ADAMSPOLISHES.com[/url][/B][/CENTER] |
01-06-2015 | #42 |
Re: Engine Cleaning
Actually, any clearcoat safe polishing compound will remove the dirt and stains. Just do small sections at a time and then when you are done, use Maguire's NXT Generation® Tech Wax® 2.0 to make it shine. Carnauba wax will yellow from the heat Same trick goes for your polished wheels
05-24-2015 | #43 | |
Re: Engine Cleaning
At 19.95 a bottle I didn't want to spend $40.00 just to try their product. I'll buy a clearcoat safe compound off the shelf. |
05-21-2017 | #44 |
Re: Engine Cleaning
Anyone trying this? Polishing your engine?
Recently I found a product called "RamRodz". They are like Q-Tips on steroids. They are intended as gun cleaning tools, but they work excellently for polishing hard to reach engine parts. They range in size from .17 inch dia. up to 1/2 inch dia. They use bamboo sticks that are quite flexible to get into tight places, but strong enough to not break easily. A full selection box contains 680 swabs, so you have enough to last a long time. I have found many uses for these. |
06-02-2017 | #45 | |
Re: Engine Cleaning
I will be using it to clean the engine also . Thanks for the tips Jim and of course Dylan from Adams products also . Last edited by Tripler; 06-02-2017 at 08:22 AM. |
06-18-2017 | #46 |
Re: Engine Cleaning
I've found that using anything with abrasives will change the finish anywhere you use it.
06-26-2017 | #47 |
Re: Engine Cleaning
Just cleaned my LT5 engine to a like new clean with Arm and Hammer Extreme White Toothpaste. About 3 hours labor, 1/2 tube of toothpaste, 1 brush, and a pint spray bottle of water. Going to check out the Maguires NXT wax.
Sent from my SAMSUNG-SM-G900A using ZR-1 Net Registry mobile app |
07-07-2017 | #48 | ||
Re: Engine Cleaning
Welcome to the Registry Forum 90C4ZR1 Guess we know what you are driving I have Number 3032 the last 1990 sold to the public
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-07-2017 at 05:52 PM. |
07-11-2017 | #49 |
Re: Engine Cleaning
I used Arm and Hammer Extreme Whitening Toothpaste to clean my LT5 to show room look. I used a toothbrush originally, but on doing touchup I used a microfiber cloth on my finger tip, dipped in water, and a dab of toothpaste. Man I was really surprised how good it looks. I rub a bit and spray with water from a spray bottle and dry. Although the toothbrush did the original work, I prefer the microfiber wrapped on my finger. You can actually see the oxidation removed on the cloth. Took me about 3.5 hours of love and labor.
08-01-2017 | #50 | |
Re: Engine Cleaning
