Old 09-09-2013   #1
alnukem
Default If/When you go to siamesed Intakes?
In a conversation on Sunday, One of the evil influences, which shall nameless("ZZZZZR1") started talking about siamesed intake ports for a 385 cube engine. It got me wondering, when & what parameters to use this method. I do comprehend the concept of drawing from 2 ports. I am sure RPM & Engine Size dictates use, just curious when. And, if cylinder porting would be different. I doubt I would ever do, just curious how it is used. Thanks, Tim
Old 09-09-2013   #2
Default Re: If/When you go to siamesed Intakes?
I have one on my 350 w/cams.....have not been to the dyno but trust me no loss in torque.....pete drove it as well and came to the same conclusion. In fact, someone put it on a lift and checked the revolutions because they thought it has a 4.10 gear.
Old 09-09-2013   #3
Daniel_Mc
Daniel_Mc's Avatar
Originally Posted by alnukem View Post
..........("ZZZZZR1") stared talking about siamesed intake ports for a 385 cube engine...........
Now why would he go and do that??
Lee,
The set up on the 90 you did is pretty much where I want to go eventually. Good gains for the amount of work IMHO.
-Daniel
Daniel_Mc is offline   Reply With Quote
Old 09-09-2013   #4
Kevin
Kevin's Avatar
Siamesed and dropped plenum on a 385 is sexy. We need to meet up soon
Old 09-09-2013   #5
Pic after rough porting was done:
Stock:
Old 09-10-2013   #6
RHanselman
RHanselman's Avatar
You are correct sir! Beware of the pretenders, unless it looks like this it's not a true siamesed plenum... This is my 93'
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 09-10-2013   #7
Ron, I would say this is more of a monorunner than siamesed.......they actually cut the runner out and reweld.....
Old 09-10-2013   #8
RHanselman
RHanselman's Avatar
Ya Lee, that's a common mistake. No such thing as a mono-runner. The plenums pictured are referred to as Siamese’d. The plenums that have been joined internally only are referred to as a fully ported. Lot's of differance in flow and price...
Cheers,
Ron Hanselman
Founding Member #80
Old 09-10-2013   #9
RHanselman
RHanselman's Avatar
TQ is still good on my 368
Ron Hanselman
Founding Member #80
Old 09-09-2013   #10
Kevin
Kevin's Avatar
WANT!
Tags
ported heads, porting, siamesed
