Old 04-27-2012   #61
Default Re: B&B Fusion: First Look
Originally Posted by Locobob View Post
A/F looked fine, had kind of an extended tip in lean out but by 4000rpm it was solidly in the 12.5 range and stayed there.
Bob,
When I get to the dyno in early June we'll find out if the DynoMaxs' had any effect on AFR with my car. The SW Xpipe did lean things out a bit
after replacing the MFlow resonator with it. AFR went from about 13 up to 13.4. Bringing AFR back down gained about 15hp. No gain in bumping timing past 29d.
Old 04-27-2012   #62
ScottZ95ZR1
ScottZ95ZR1's Avatar
Originally Posted by VetteMed View Post
As long as your vacuum tubing is stiff enough so as not to collapse, and large enough diameter to provide the "volume" of vacuum needed to operate the actuator(s), the length of the tubing isn't really much of an issue. Of course, I am no engineer -- but in my mind at least, it's like choosing the size of wiring. The length isn't much of an issue as long as the gauge is large enough.
Thank you Andrew!
ScottZ95ZR1 is offline   Reply With Quote
Old 04-27-2012   #63
Originally Posted by tf95ZR1 View Post
It seems to be hit and miss with B&B.
First time I called to order a 3" X pipe they said no,
have to buy entire system and/or trade in the resonator.
Next call, I got my B&B X pipe. Not cheap....
The SW X pipe to me was $278 a couple years ago. The B&B is essentially the same. How much for their X??
P.
Old 04-27-2012   #64
Pete
Pete's Avatar
Bob,
Wait till June WTF.
I would say find another Dyno.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-27-2012   #65
ScottZ95ZR1
P.
I bought one from B&B in 2010 for $300
Old 04-27-2012   #66
Originally Posted by Pete View Post
Wait till June WTF.
Pete
Pete,
Just trying to keep apples to apples.
Old 04-27-2012   #67
Locobob
Originally Posted by ScottZ95ZR1 View Post
I have a question for the many of you here smarter than I am...
I've installed just the fusion exhaust but haven't decided where I want to mount the vacuum reservoir and switch plate.
I think I would like to put it forward left in the engine compartment where the AIR pump once was - plenty of space there.
But does it makes sense to have the reservoir so far from the actuators.... or would it really not matter with vacuum?
Any help here would be greatly appreciated!
There is space to mount the plate behind the rear license plate and also inside the left rear fender. Steve put his behind the rear plate and it worked out rather well. I can't really see the point in going to the front of the car and then all the way to the back.
Robert
Old 04-27-2012   #68
It would be nice if B&B would rotate the actuator upward a bit, that would decrease its exposure to debris and make it less visible from the rear. There is room to do this.
Concur thats the only thing I dislike about this mod. Stone city
Old 08-05-2018   #69
emmvette
emmvette's Avatar
Digging up this old thread. I'm installing this on my car and am not getting a 12V output from the little black box. I verified there is 12V on the input (red) wire with the ignition on; and the black wire is grounded. I'm wondering if the little box is just bad. I can't think of a way to test it.
Also, wondering how your exhausts are holding up. Are the valves and electronics still functioning well?
emmvette is offline   Reply With Quote
