Old 03-10-2012   #1
Default Next! Top End Touchup
Now that the front suspension has been rebuilt and re-assembled, I dropped the old oil and some coolant while the car is still on jack stands.
I am going to get the plenum and IH's repainted. While off, I thought I would measure the head ports from GVDs porting. Borrowed a snap guage from Pete and I will be measuring ports at 3 different points, valve bowl entry, secondary throttle plate(where they were), and top. Meantime, I've measured the IH and plenum porting job I did nearly 3 years ago and found it needs to be re-done somewhat. The ports are not as uniform as they should be at 36mm. I almost finished one IH in about 2.5hrs. Ball rolls thru the ports now. One more port to go. Mostly touch up but the ports are looking more uniform. PAssenger side looks like it needs more attention than D/S. Maybe I'll have both IHs done this weekend. Once the porting is done, the plenum and IHs go to the stripper to remove paint and then they get re-painted to visually complement the cam covers.
